[Qgis-user] QGIS big fail in deleting Shapes!!
Mark Brooks
markb222 at gmail.com
Wed Jan 20 01:35:39 PST 2016
Thanks for that Even
On 20 January 2016 at 09:23, Even Rouault <even.rouault at spatialys.com>
wrote:
> Le mercredi 20 janvier 2016 09:04:52, Neumann, Andreas a écrit :
> > Hi,
> > Regarding GDAL update to version 2.0: if your platform is Windows, I
> > already asked Jürgen if he can update to version 2.0 - as there are
> > other issues/new functionality that would be enabled by moving to GDAL
> > 2.0 (like better Geopackage support, curve support (for Interlis and
> > later also Geopackage) and probably some other improvements). So there
> > is a good chance that QGIS 2.14 on Windows will ship with GDAL 2.0.
> FYI, GDAL 2.0.2 RC1 should be out for the end of the week.
> > @Uwe: while I totally agree that this is a severe error that should be
> > fixed, apparently it isn't that easy. And I can only recommend that you
> > should not build your GIS projects around Shapefiles. There are other
> > options around, like Postgis, SpatiaLite or Geopackage that also allows
> > to share data with ArcGIS. And you could also store and edit your data
> > in SpatiaLite, Postgis or Geopackage and then only export to Shapefiles
> > if you need to deliver your data to your client. Shapefiles are from the
> > past century and should be avoided - for many reasons.
> > I also remember that Marco Hugentobler (Sourcepole) was contracted to
> > fix these Shapefile issues for the province of Vorarlberg - though I may
> > be wrong. So there is already someone investing to fix this bug. Marco -
> > correct me if I am wrong.
> > Hopefully, there can be a fix about this Shapefile issue in QGIS 2.14
> > Andreas
> > On 2016-01-20 07:34, Matthias Kuhn wrote:
> > > Hi all,
> > > Here is some more eplanation of the issue:
> http://gis.stackexchange.com/questions/58101/how-to-avoid-creating-corrup
> > > t-shapefiles-during-editing/79677#79677
> > > I spent quite some time to fix this issue as much as possible from QGIS
> > > side (Hint: "they" are not just lazy and ignore problems ;-) ) It seems
> > > that there is also a second (closely related) problem left to be solved
> > > and it looks that it can be solved by shipping a newer GDAL version.
> > > Apparently the issue has not been completely solved yet and apparently
> > > it is considered to be from "critical" over "big fail" to "fatal" from
> > > the audience. It would be awesome if you could ask the maintainer of
> > > your operation system's builds for a quote to ship QGIS with GDAL 2.0
> on
> > > your operation system. We will gladly provide you with email addresses.
> > > Best regards,
> > > Matthias
> > > On 01/19/2016 10:54 PM, Mats Elfström wrote:
> > > Hi!
> > > While all that Nicolas and Uwe says is generally true and reasonable,
> it
> > > is also true that bugs and errors can be more or less dangerous. With
> > > limited resources, it is even more important that bugs are handled
> > > according to a simple risk analysis. In this case, it would go
> something
> > > like this:
> > > What is the probability that users will edit shape files (high,
> moderate,
> > > low): High What is the probability that QGIS will damage shape files:
> > > Moderate (as I understand) What is the severity of the potential damage
> > > (fatal, reparable, negligible): Fatal And High * Moderate * Fatal
> equals
> > > a probable risk for fatal damage, which ought to prompt for a rapid fix
> > > of ths bug, regardless of where it resides in the QGIS ecosystem. But
> > > oddly enough, I have browsed through many of the posts on the shape
> file
> > > issue, but have yet to find a technical description of the exact cause
> > > and origin of this bug.
> > > Regards, Mats.E
> > > 2016-01-19 22:14 GMT+01:00 Saber Razmjooei
> > > <saber.razmjooei at lutraconsulting.co.uk>:
> > > Dear Uwe,
> > > There are some work-arounds and solutions provided within the ticket.
> > > Also, work is underway to resolve the issue in the next LTR release.
> Last
> > > time I checked (5 minutes ago) it is still present in master.
> > > I totally agree with you that there should be a warning to users to
> make
> > > them aware of this limitation.
> > > In general, QGIS and other GIS/non-GIS proprietary software come with
> > > bugs. The reason developers haven't fixed this bug and other bugs is
> due
> > > to lack of resources (time, money).
> > > The project steering committee is committed to resolving the bugs and
> > > they have already allocated a big proportion of their income for bug
> > > fixing. You can see last year's financial report hear:
> > > http://qgis.org/en/_downloads/PublicQGISfinancialreport2014.pdf
> > > If you think, there should be more work done to increase the quality of
> > > QGIS, you can get involved or contribute to the project:
> http://qgis.org/en/site/getinvolved/governance/sponsorship/sponsorship.ht
> > > ml
> > > Regards,
> > > Saber
> > > FROM: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] ON BEHALF
> OF
> > > Uwe Fischer SENT: 19 January 2016 19:10
> > > TO: 'qgis-user ML'
> > > SUBJECT: [Qgis-user] QGIS big fail in deleting Shapes!!
> > > Hello all,
> > > today I was working on a shape dataset and I had to delete some
> features.
> > > Later I opened the shapefile in ArcMap by chance and I found that the
> > > features were not deleted. They still did exist. I repeated the process
> > > - and got the same result. Then, searching the internet, I found this
> > > incredible post: https://hub.qgis.org/issues/11007
> > > It is a well known problem (for 1,5 years!!) that _QGIS is not able to
> > > delete shapes in a reliable way_!! I was horrified to read this because
> > > it is the same as if a Word processor would not be able to delete a
> > > letter from a text. I cannot understand why the QGIS developers haven't
> > > fix that yet. If QGIS really wants to compete with ArcMap, they should
> > > fix it as soon as possible. At least, the according menu entries or
> > > buttons should be inactivated if they don't bring out reliable results.
> > > My questions are:
> > > · is this information still up to date? I can't read all of the
> > > 80 answers to the post now to get in-depth information ...
> > > · does anybody have information about how they are planning to
> > > handle this problem at the development team?
> > > · is there a workaround for this? Do the GRASS vector tools
> bring
> > > out reliable results?
> > > · are there more of those software errors in QGIS that might
> lead
> > > to huge problems in working on vector data and sharing them with
> others?
> > > If so, is there a „black list" of things one is never allowed to use in
> > > QGIS if you don't want to destroy your datasets?
> > > Regards,
> > > Uwe Fischer
> > > This email and any files transmitted with it are confidential and
> > > intended solely for the use of the individual or entity to whom they
> are
> > > addressed. If you have received this email in error please notify the
> > > system manager. This message contains confidential information and is
> > > intended only for the individual named. If you are not the named
> > > addressee you should not disseminate, distribute or copy this e-mail.
> > > Please notify the sender immediately by e-mail if you have received
> this
> > > e-mail by mistake and delete this e-mail from your system. If you are
> > > not the intended recipient you are notified that disclosing, copying,
> > > distributing or taking any action in reliance on the contents of this
> > > information is strictly prohibited.
> > > Whilst reasonable care has been taken to avoid virus transmission, no
> > > responsibility for viruses is taken and it is your responsibility to
> > > carry out such checks as you feel appropriate.
> > > If this email contains a quote or offer to sell products, carry out
> work
> > > or perform services then our standard terms and conditions [1] shall
> > > apply unless explicitly stated otherwise.
> > > Saber Razmjooei and Peter Wells trading as Lutra Consulting.
> > > _______________________________________________
> > > Qgis-user mailing list
> > > Qgis-user at lists.osgeo.org
> > > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160120/dcf11836/attachment.html>
