[Qgis-user] field calculator remains hidden
    Jürgen E. Fischer
    jef at norbit.de
    Wed Jan 20 09:22:22 PST 2016
Hi Christine,
On Wed, 20. Jan 2016 at 08:36:58 -0800, Christine wrote:
> Have also installed QGIS 2.12 on the same machine and the problem now
> concerns also this version although it wasn't caused by it. So I assume,
> there are common settings used for both versions. Can anybody point me to
> this place and give some advice how to reset the values for field calculator
> dialog ?
Maybe the dialog was moved to a second screen that is not available anymore?
Anyway in Settings/Options there is a System tab where you can reset the UI
settings.   That should bring the field calculator back.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160120/88f9177b/attachment.sig>
