[Qgis-user] QGIS Server sometimes not sending commits to postgis
    Alessandro Pasotti
    apasotti at gmail.com
    Tue Jan 26 05:29:43 PST 2016
2016-01-26 13:37 GMT+01:00 jaitor <sigeo.agmartin at getxo.eus>:
> Hi,
> I am running a Windows Server 2012 server.
> PostgreSQL 9.3.5, 64-bit
> POSTGIS 2.1.3
> QGIS Server 2.6.1-2
> QGIS Desktop 2.8.3
> I am using a Microsoft Surface Pro 4 tablet using QGIS Desktop 2.12 to edit
> some layers stored in the Postgresql database. The layers in the tablet are
> WFS layers served by QGIS Server.
> When I toogle editing after inserting some data in the layer to force the
> data to be sent and stored in the server sometimes the commit is not being
> done from QGIS Server to the Database.
> I can see that the POST http request arrives to the server ok, but
> sometimes
> I can't see a commit (update) in the database and some other times it works
> ok and does the commit.
> I ensure every time that internet connection is fine.
> When loading the QGIS project with 50 WFS layers in the tablet (client),
> sometimes two or three layers are not read and I need to click in apply
> several times until they are read properly and the project finishes
> loading.. I don't know if this problem is related to the one I mentioned
> before.
> The problem that worries me is the first one, because there is people
> working in field inserting data the whole day, and when they arrive to
> their
> office they connect teh tablet to wifi (or even ethernet cable) to ensure
> internet is fine and they toogle edition to save changes. As mentioned
> before, sometimes data is not stored in postgis but no error is propagated
> to QGIS Client, so the user thinks that the data has been stores correctly.
> The funny thing is that they have been working for 40 days and hey only got
> this problem once, but since last week they have had this problem every
> day...
> I've been trying to activate QGIS Server logs to see what error it is
> giving
> adding these two lines to D:\OSGeo4W\httpd.d\httpd_qgis.conf
> SetEnv QGIS_SERVER_LOG_FILE /var/tmp/qgislog.txt
> SetEnv QGIS_SERVER_LOG_LEVEL 0
> But no log file is being generated.
If you are using FAST CGI, you can try:
FcgidInitialEnv QGIS_DEBUG 1
FcgidInitialEnv QGIS_SERVER_LOG_FILE /tmp/qgis-000.log
FcgidInitialEnv QGIS_SERVER_LOG_LEVEL 0
Hope this helps.
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160126/89cb48c2/attachment.html>
