[Qgis-user] Wrong grid values in the print composer
Neumann, Andreas a.neumann at carto.net
Mon Jul 4 04:49:00 PDT 2016
How did you add your background map(s)? Perhaps with the OpenLayers
plugin?
It is a known-issue of this plugin that it has a false offset in print
composer. You can use the "Quick Map Services" plugin instead of the
"OpenLayers" plugin and your print composer/print outs should be fine.
Andreas
On 2016-07-04 13:00, FAKT - Assistant wrote:
> Hello everybody from Germany!
> I'm a beginner in using QGIS for mapping. And now I have my first problem with it, I hope someone can help me with it.
> Thanks already in advance!
> I use QGIS 2.14.1 "Essen".
> I've added a map from OpenStreetMap and a satellite picture from the area I want to map. I added also some rectangles etc.
> All maps were added with the coordinated reference system "EPSG: 3857 WGS 84/ Pseudo Mercator".
> When I check the coordinates with Google Earth they are all right.
> But when I open the print composer and add my map which I made with the help of OpenStreetMap and satellite picture something is wrong. When I add a new grid it shows some values which not match with the coordinates in the editing mode. The values start with 0 in the corners and it seems like there is missing the connection between the grid in the editing mode and the grid in the print composer. But I don't have an idea how to fix it.
> Can someone of you tell me how I can solve the problem?
> Thank you very much for your efforts!!!
> Greetings from Germany
> Michael
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160704/de681287/attachment.html>
