[Qgis-user] Placement of attribute tables in print composer
Martin Stubbs martin at mstubbs.co.uk
Tue Jul 5 03:46:05 PDT 2016
I am producing a multi page document using the atlas function in print
composer. I have pairs of pages with a map on the left side and 4
attribute tables on the facing page showing details of 4 different
objects on the map. For each pair of pages there are a variable number
of objects shown of each type. Each object is fetch from its own postgis
table as the fields stored for each object is different.
At the moment I have the attribute tables defined to handle the largest
number of items found on the map but this means, on some pages, there
are large gaps before the next table starts. Would it be possible to
have a variable exported from an attribute table that could be used to
position the next table a suitable distance apart?
Thanks for the help
Martin
