[Qgis-user] Placement of attribute tables in print composer
Richard McDonnell
richard.mcdonnell at opw.ie
Wed Jul 6 03:35:46 PDT 2016
Martin,
You can specify the position and size of the table?tables using
attributes, you could set up an x and y column on your tables which you
could use the *Data defined Overide* options to set your location this
is under *Attribute Table, Item Options, Position and Size *on the composer.
Might be a solution for you!
Regards,
Richard.
On 05/07/2016 11:46, Martin Stubbs wrote:
> Hi,
> I am producing a multi page document using the atlas function in print
> composer. I have pairs of pages with a map on the left side and 4
> attribute tables on the facing page showing details of 4 different
> objects on the map. For each pair of pages there are a variable number
> of objects shown of each type. Each object is fetch from its own
> postgis table as the fields stored for each object is different.
> At the moment I have the attribute tables defined to handle the
> largest number of items found on the map but this means, on some
> pages, there are large gaps before the next table starts. Would it be
> possible to have a variable exported from an attribute table that
> could be used to position the next table a suitable distance apart?
> Thanks for the help
> Martin
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
*_Richard McDonnell_*
*GIS Specialist PgD GIS AssocSCSI*
*OPW FRM Data Management*
*52 Stephens Green, Dublin 2.*
TEL: 01 6476543
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160706/cd81978f/attachment.html>
