[Qgis-user] Debian users: please confirm bug around SVG symbol previews
    Matthias Kuhn
    matthias at opengis.ch
    Thu Jul  7 14:59:51 PDT 2016
On 07/07/2016 10:55 PM, Nyall Dawson wrote:
> On 7 Jul 2016 11:44 PM, "Neumann, Andreas" <a.neumann at carto.net
> <mailto:a.neumann at carto.net>> wrote:
> > Hi Richard,
> > Thanks - it behaves exactly the same on Ubuntu.
> > I am inclined to close this bug http://hub.qgis.org/issues/14255 if
> Paolo is the only one experiencing this issue. Seems like a local
> issue with his directory structure.
> I can help clarify the situation a bit:
> - In 2.14 a bug was introduced which automatically added user's home
> folders to the svg paths. That's fixed now, but users may still have
> that path included.
> - there's a valid bug regarding endless loops with symlinks, that
> should be fixed
> - but mostly, I think the svg loading needs to be moved to a non
> blocking background thread. So please keep the report open until this
> is addressed.
That sounds all good.
I think the main reason the topic was brought up was that it's one of
the few blockers which are still open.
Let's split it into two issues:
 Moving to a background thread, that's probably a feature request, so we
could just downgrade that to a "hight" priority one.
 For the endless loop, we can leave that as blocker (in the end you have
to kill the app, so it's like a crash with lost unsaved work).
Matthias
> Nyall
> > Andreas
> > On 2016-07-07 15:37, Richard Duivenvoorde wrote:
> >> On 07-07-16 15:15, Neumann, Andreas wrote:
> >>> Hi Nelson,
> >>> Thanks for checking.
> >>> Are you sure the users home directory is added to the SVG paths by
> >>> default on Debian? I can't confirm this on Ubuntu.
> >>> I thought that by default this setting is empty.
> >> I'm on Debian Testing;
> >> I do not have a clean install available, but if I start qgis from
> >> commandline here with a fresh config:
> >> qgis --configpath /tmp/foo
> >> I end up with two items in the svg path:
> >> /home/richard/apps/qgis/master/debug/share/qgis/svg/
> >> /tmp/foo/svg/
> >> The first one is the svg directory of my installation (self compiled),
> >> the second is a svg directory in the configpath (which is your home dir
> >> by default I think?)
> >> Regards,
> >> Richard
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> >> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Matthias Kuhn
OPENGIS.ch - https://www.opengis.ch
Spatial • (Q)GIS • PostGIS • Open Source
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160707/c19ed736/attachment.html>
