[Qgis-user] QGIS won't open Martian .img files
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Fri Jul 8 06:13:30 PDT 2016
Qgis uses gdal library to deal with rasters.  I found some information in the link below.  Perhaps the gdal user group could help.  It is possible that you need an extra driver to read the files. (Perhaps installable via the osgeo4w Qgis installer).  You can also try the semi automatic classification plugin that is use for remote sensing imagery.  Perhaps there is something in that plugin that could help.
http://www.gdal.org/frmt_pds.html
Nicolas
On Jul 8, 2016 08:25, "Adam Neather [via OSGeo.org]" <ml-node+s1560n5275411h2 at n6.nabble.com> wrote:
	Hello everyone,
I'm trying to use QGIS to get topographic profiles from Mars Global
Surveyor data. (Example link below.) While QGIS will open the .lbl files
as a raster with no problem, I always get the error "Unsupported Data
Source: /Users/username/Desktop/megr00n180hb.img is not a supported
raster data source" when trying to open the .img. (In fact, this is only
under Windows 10; QGIS on Mac OS X refuses to open the .lbl files, too,
with the same error message.)
The .img files included with the sample data for the tutorials loads
fine, so I'm not sure what it is I'm doing wrong.
A colleague has suggested it may be because I need a plug-in to be able
to read NASA's Planetary Data System file format, but I can't find
anything about that in the official plug-in repository or when searching
online.
Weird thing is, I'm returning to a project from a few years ago, and we
used QGIS back then to work with this data set, so I'm as confused as
it's possible to get!
Any help greatly appreciated,
http://pds-geosciences.wustl.edu/mgs/mgs-m-mola-5-megdr-l3-v1/mgsl_300x/meg004/ --
Adam Neather
Qgis-user mailing list
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/QGIS-won-t-open-Martian-img-files-tp5275411.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-won-t-open-Martian-img-files-tp5275411p5275423.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160708/9152960a/attachment.html>
