[Qgis-user] Minimum bounding circle from cluster of points
SEGGIE Graeme
gseggie at systra.com
Fri Jul 8 08:15:58 PDT 2016
I don’t have enough experience of coding steps in QGIS yet, but could you do the following?
For each set of points sharing a plot ID attribute value:
Identify the distances between all points.
Take the furthest apart pair (or one set of if more pairs are equal), which would become a diameter.
From this chosen pair, get the mid-point, which becomes the midpoint of the circle.
Buffer the identified midpoints as circles with size of radius (half max distance identified) to get circle containing all others in each set.
I think that would get all of them, or at least I can’t think of a situation where any longest pair identified could be further away from another point to be left out.
Graeme.
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Tina Cormier
Sent: 08 July 2016 14:50
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Minimum bounding circle from cluster of points
Hi all,
Looking for help aggregating some field data subplots to the plot level. In the attached screenshot, you can see clusters of 4 points (4 subplots = 1 plot). I'd like to create a circle around each cluster that is the smallest circle that would encompass all 4 points. Sort of like a convex hull, but a circle (convex hull, in this case, would give me a triangle). Is there a tool or a series of steps to accomplish this without doing it manually? In the attribute table, I have a unique ID for each plot/cluster. So for each plot ID (in this case, consisting of 4 subplots), I'd like to build a circle around all of the subplots.
I should also mention that it's not always 4 points (subplots), and they aren't always covering the same size area on the ground.
I have QGIS 2.14.2 as well as one of the nightly builds from a few weeks ago (can download the newest one if necessary).
Thanks in advance for any ideas/insights! Google has not helped me so much yet with this one!
Tina
[Inline image 2]
This message has been verified and checked by company's antispam system. Click here<https://www.mailcontrol.com/sr/hzZxL+RGjW!GX2PQPOmvUlRg0f8c3ZDCDEGp1VnSwMOgemTiV2FYJ45tXRcGdAw87+NHA8YIK0TJaydNu2tBwg==> to report this message as a spam.
======================================================== This message has been scanned for malware. This message and any attachments (the "message") are confidential, intended solely for the addressees, and may contain legally privileged information. Any unauthorised use or dissemination is prohibited. E-mails are susceptible to alteration. Neither our company or any of its subsidiaries or affiliates shall be liable for the message if altered, changed or falsified. ========================================================= Ce message a ete verifie et ne contient pas de programme malveillant. Ce message et toutes les pieces jointes (ci-apres le "message") sont confidentiels et susceptibles de contenir des informations couvertes par le secret professionnel. Ce message est etabli a l'intention exclusive de ses destinataires. Toute utilisation ou diffusion non autorisee est interdite. Tout message electronique est susceptible d'alteration. Notre societe et ses filiales declinent toute responsabilite au titre de ce message s'il a ete altere, deforme falsifie. =========================================================
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160708/c9aaf722/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160708/c9aaf722/attachment.png>
