[Qgis-user] Contours to DEM surface
Martin Schneppmüller
mstrms2000 at gmail.com
Tue Jul 12 09:56:01 PDT 2016
Hi Lester,
I would try to make "points from lines" (I thinks its under 'vector' -
'geometry tools' ) and then create a raster wiht the interpolation plugin (
http://docs.qgis.org/2.8/en/docs/user_manual/plugins/plugins_interpolation.html).
Maybe you can try the interpolation plugin with the lines.
The lines must have the attribute "elevation" or somthing else hope this
helps.
<Message: 4
<Date: Tue, 12 Jul 2016 16:48:47 +0100
<From: Lester Anderson <arctica1963 at gmail.com>
<To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
<Subject: [Qgis-user] Contours to DEM surface
<Message-ID:
< <CAE3taFA-OFK2+4mU3zzMKKWrxomvMXppHGOovx1CjaH2odACgQ at mail.gmail.com
<Content-Type: text/plain; charset=UTF-8
<Hello all,
<A quick one, but is there an easy route/workflow to convert a
<shapefile of elevation contours to a grid surface?
<Thanks
<Lester
<QGIS 2.10, 2.12, 2.14
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160712/6bc3affa/attachment.html>
