[Qgis-user] Contours to DEM surface
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Tue Jul 12 11:32:07 PDT 2016
Keep in mind Lester that the result will always look like a rice paddy
field with steps unless you resort to lots of smoothing. You will see
theses steps with you do a shade model from the DEM. That's a good way
to see the problem. It may no be visible by just looking at the DEM.
Nicolas
Le 2016-07-12 12:17, Anita Graser [via OSGeo.org] a écrit :
> Hi Lester
> On Tue, Jul 12, 2016 at 5:48 PM, Lester Anderson <[hidden email]
> </user/SendEmail.jtp?type=node&node=5276004&i=0>> wrote:
> A quick one, but is there an easy route/workflow to convert a
> shapefile of elevation contours to a grid surface?
> Please have a look at the solutions suggested in
> http://gis.stackexchange.com/questions/18116/creating-dem-from-contours-in-qgis
> Best wishes,
> Anita
> Qgis-user mailing list
> [hidden email] </user/SendEmail.jtp?type=node&node=5276004&i=1>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the
> discussion below:
> http://osgeo-org.1560.x6.nabble.com/Contours-to-DEM-surface-tp5275995p5276004.html
> To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==>.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Contours-to-DEM-surface-tp5275995p5276031.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160712/120283a6/attachment.html>
