[Qgis-user] infotool
Neumann, Andreas
a.neumann at carto.net
Thu Jul 14 02:19:39 PDT 2016
Hi Thomas,
What exactly would you expect? To see the form directly?
Note that the Info Tool has it's own panel titled "Identify Results". In
there you can change to different modes:
* Current Layer
* Top down, stop at first
* Top down
* Layer selection
And there is a checkbox to open the form if there is only one hit. Note
that if you have multiple hits, you need to select in the list in the
panel for which feature you want to open the form.
The "Layer selection" (context menu in the map) and the "Top down, stop
at first" are the two most useful modes in my opinion.
All of the modes should honor the "identifyable" checkbox in the project
properties.
Hope this clarifies how it behaves? If not, please clarify what exactly
fails.
Greetings,
Andreas
On 2016-07-14 10:27, Thomas Dunz wrote:
> Hi
> I encouter the following problem with the infotool in QGIS vers. 8.6, Win 7 (please notify that I translatetd the menuitems from german to english, so the might differ a littel from the original wording - but I hope, I made the point clear):
> When hitting the infotool-button or via menu "View->Object identify (Ctrl,Shift,i)", I see only the attributes written in the attributetable. Ctrl,Shift,I doesnt work at all.
> The checkbox in the menu "project->projectproperties->Layer identfiable" doesn't affect that behaviour. The attributetable attributes are shown even when "identifiable" is not marked.
> The same appears when i try out a higher version of QGIS (2.12).
> Any suggestions how to fix? Thanks in advance.
> Thomas
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160714/6ffc1b9b/attachment.html>
