[Qgis-user] Importing CSV files
Werner Macho werner.macho at gmail.com
Fri Jul 15 04:56:21 PDT 2016
Hi!
Can you give a sample of the csv file?
For example if there is 40% inside the column it can't be a integer ..
Would be good to have a look how the data looks like.
regards
Werner
On Fri, Jul 15, 2016 at 1:29 PM, Phillip Money
<phillip.money at hotmail.com> wrote:
> I have a CSV file with four columns. The first column is text, and the
> succeeding columns are percentages. I have set up a csvt file with "String",
> "Integer", "Integer", "Integer" When I import the file into QGIS as a
> delimited text layer, QGIS strips out all the percentages. They come in as
> null values. I have tried a lot of things, but can't get past this.
> For example, I have tried converting the percentages to numbers and bringing
> them in that way; same thing happens.
> I would appreciate any help.
> Regards
> Phillip Money
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
