[Qgis-user] Problems with ubuntu-unstable again
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Sun Jul 17 13:42:20 PDT 2016
Hi Angelos,
thanx a lot for the hint. It works!
This is now indeed the third variation of a working setup in a row.
We already had to enable three repositories, then two, and now it's only
one. Unfortunately the instructions on the download page never manage to
reflect those changes.
Cheers
Bernd
Am 17.07.2016, 21:36 Uhr, schrieb Angelos Tzotsos <gcpp.kalxas at gmail.com>:
> Hi Bernd,
> This will get you to a working setup:
> 1. Please remove all previous installed versions with apt-get purge qgis
> 2. Enable only UbuntuGIS-Unstable and remove all other ppa's
> 3. apt-get install qgis.
> This will get you QGIS 2.14.3. I have several reports that this works
> fine.
> Best,
> Angelos
> On 07/17/2016 09:47 PM, Bernd Vogelgesang wrote:
>> Hi all,
>> now I enabled http://qgis.org/ubuntugis-ltr and I face the same
>> problems as below, but only for 2.14 version now.
>> Is there any way to install a recent QGIS with my beloved ubuntugis
>> features from the repositories, or is this just a local problem?
>> I need to get this up and running as I would like to do some work ...
>> Cheers
>> Bernd
>> Am 16.07.2016, 15:11 Uhr, schrieb Bernd Vogelgesang
>> <bernd.vogelgesang at gmx.de>:
>>> Hi Jürgen,
>>> thanks for the reply.
>>> Ok, as I understood your words, I disabled ubuntugis and enabled
>>> instead:
>>> deb http://qgis.org/ubuntugis-nightly-release trusty main
>>> deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu trusty
>>> main
>>> But still, QGIS will not install:
>>> bernd at bernd-TERRA-PC ~ $ sudo apt-get install qgis
>>> Reading package lists... Done
>>> Building dependency tree
>>> Reading state information... Done
>>> Some packages could not be installed. This may mean that you have
>>> requested an impossible situation or if you are using the unstable
>>> distribution that some required packages have not yet been created
>>> or been moved out of Incoming.
>>> The following information may help to resolve the situation:
>>> The following packages have unmet dependencies:
>>> qgis : Depends: libgdal.so.1-1.11.2
>>> Depends: libgdal1h (>= 1.8.0) but it is not going to be
>>> installed
>>> Depends: libqgis-analysis2.16.0 but it is not going to be
>>> installed
>>> Depends: libqgis-app2.16.0 but it is not going to be
>>> installed
>>> Depends: libqgis-core2.16.0 but it is not going to be
>>> installed
>>> Depends: libqgis-gui2.16.0 but it is not going to be
>>> installed
>>> Depends: libqgis-networkanalysis2.16.0 but it is not going
>>> to be
>>> installed
>>> Depends: python-qgis (=
>>> 1:2.16.0+git20160712+1b016e4+20trusty-ubuntugis) but it is not going
>>> to be
>>> installed
>>> Depends: qgis-providers (=
>>> to be
>>> installed
>>> E: Unable to correct problems, you have held broken packages.
>>> Actually, I do not intend to have something "unstable" or exotic, but
>>> simply just the same
>>> flavour as when I use the OSGEO4W-installer on Windows.
>>> Even after years, I can't figure out from the help pages what all the
>>> stuff means and how things have to be handled in case something
>>> doesn't work (which happens actually at each change of version, but
>>> the way to resolve this seems to be different every time).
>>> Thankful for any hint
>>> Bernd
>>> Am 15.07.2016, 21:28 Uhr, schrieb Jürgen E. Fischer <jef at norbit.de>:
>>>> Hi Bernd,
>>>> On Fri, 15. Jul 2016 at 18:36:06 +0200, Bernd Vogelgesang wrote:
>>>>> Will the rebuilding be triggered automatically, or do I have to
>>>>> "trigger" someone to have a look at it ?
>>>> No, the dependencies are not actively tracked and therefore no
>>>> automatic
>>>> rebuilds are triggered.
>>>> But the nightlies are rebuilt with current dependencies whenever a
>>>> commit
>>>> (backport) has happened in the meantime. So you can resort to those
>>>> for
>>>> "unstable" distributions (ie. distributions that have changed between
>>>> releases).
>>>> The next regular rebuild is on 29.7. for the 2.14.1 and 2.16.1 point
>>>> releases.
>>>> Jürgen
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
