[Qgis-user] Problems with ubuntu-unstable again
    Bernd Vogelgesang
    bernd.vogelgesang at gmx.de
    Sun Jul 17 11:47:59 PDT 2016
Hi all,
now I enabled http://qgis.org/ubuntugis-ltr and I face the same problems
as below, but only for 2.14 version now.
Is there any way to install a recent QGIS with my beloved ubuntugis
features from the repositories, or is this just a local problem?
I need to get this up and running as I would like to do some work ...
Cheers
Bernd
Am 16.07.2016, 15:11 Uhr, schrieb Bernd Vogelgesang
<bernd.vogelgesang at gmx.de>:
> Hi Jürgen,
> thanks for the reply.
> Ok, as I understood your words, I disabled ubuntugis and enabled instead:
> deb http://qgis.org/ubuntugis-nightly-release trusty main
> deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu trusty
> main
> But still, QGIS will not install:
> bernd at bernd-TERRA-PC ~ $ sudo apt-get install qgis
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> Some packages could not be installed. This may mean that you have
> requested an impossible situation or if you are using the unstable
> distribution that some required packages have not yet been created
> or been moved out of Incoming.
> The following information may help to resolve the situation:
> The following packages have unmet dependencies:
>     qgis : Depends: libgdal.so.1-1.11.2
>            Depends: libgdal1h (>= 1.8.0) but it is not going to be
> installed
>            Depends: libqgis-analysis2.16.0 but it is not going to be
> installed
>            Depends: libqgis-app2.16.0 but it is not going to be installed
>            Depends: libqgis-core2.16.0 but it is not going to be
> installed
>            Depends: libqgis-gui2.16.0 but it is not going to be installed
>            Depends: libqgis-networkanalysis2.16.0 but it is not going to
> be
> installed
>            Depends: python-qgis (=
> 1:2.16.0+git20160712+1b016e4+20trusty-ubuntugis) but it is not going to
> be
> installed
>            Depends: qgis-providers (=
> be
> installed
> E: Unable to correct problems, you have held broken packages.
> Actually, I do not intend to have something "unstable" or exotic, but
> simply just the same
> flavour as when I use the OSGEO4W-installer on Windows.
> Even after years, I can't figure out from the help pages what all the
> stuff means and how things have to be handled in case something doesn't
> work (which happens actually at each change of version, but the way to
> resolve this seems to be different every time).
> Thankful for any hint
> Bernd
> Am 15.07.2016, 21:28 Uhr, schrieb Jürgen E. Fischer <jef at norbit.de>:
>> Hi Bernd,
>> On Fri, 15. Jul 2016 at 18:36:06 +0200, Bernd Vogelgesang wrote:
>>> Will the rebuilding be triggered automatically, or do I have to
>>> "trigger" someone to have a look at it ?
>> No, the dependencies are not actively tracked and therefore no automatic
>> rebuilds are triggered.
>> But the nightlies are rebuilt with current dependencies whenever a
>> commit
>> (backport) has happened in the meantime.  So you can resort to those for
>> "unstable" distributions (ie. distributions that have changed between
>> releases).
>> The next regular rebuild is on 29.7. for the 2.14.1 and 2.16.1 point
>> releases.
>> Jürgen
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
