[Qgis-user] Problems with ubuntu-unstable again
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Sat Jul 16 06:11:48 PDT 2016
Hi Jürgen,
thanks for the reply.
Ok, as I understood your words, I disabled ubuntugis and enabled instead:
deb http://qgis.org/ubuntugis-nightly-release trusty main
deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu trusty
main
But still, QGIS will not install:
bernd at bernd-TERRA-PC ~ $ sudo apt-get install qgis
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
    qgis : Depends: libgdal.so.1-1.11.2
           Depends: libgdal1h (>= 1.8.0) but it is not going to be installed
           Depends: libqgis-analysis2.16.0 but it is not going to be
installed
           Depends: libqgis-app2.16.0 but it is not going to be installed
           Depends: libqgis-core2.16.0 but it is not going to be installed
           Depends: libqgis-gui2.16.0 but it is not going to be installed
           Depends: libqgis-networkanalysis2.16.0 but it is not going to be
installed
           Depends: python-qgis (=
1:2.16.0+git20160712+1b016e4+20trusty-ubuntugis) but it is not going to be
installed
           Depends: qgis-providers (=
installed
E: Unable to correct problems, you have held broken packages.
Actually, I do not intend to have something "unstable" or exotic, but
simply just the same
flavour as when I use the OSGEO4W-installer on Windows.
Even after years, I can't figure out from the help pages what all the
stuff means and how things have to be handled in case something doesn't
work (which happens actually at each change of version, but the way to
resolve this seems to be different every time).
Thankful for any hint
Bernd
Am 15.07.2016, 21:28 Uhr, schrieb Jürgen E. Fischer <jef at norbit.de>:
> Hi Bernd,
> On Fri, 15. Jul 2016 at 18:36:06 +0200, Bernd Vogelgesang wrote:
>> Will the rebuilding be triggered automatically, or do I have to
>> "trigger" someone to have a look at it ?
> No, the dependencies are not actively tracked and therefore no automatic
> rebuilds are triggered.
> But the nightlies are rebuilt with current dependencies whenever a commit
> (backport) has happened in the meantime.  So you can resort to those for
> "unstable" distributions (ie. distributions that have changed between
> releases).
> The next regular rebuild is on 29.7. for the 2.14.1 and 2.16.1 point
> releases.
> Jürgen
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
