[Qgis-user] Value relation option in QGIS
Chris Buckmaster
chris.buckmaster at runnymede.gov.uk
Mon Jul 18 03:58:31 PDT 2016
Hi
I have a field in a PostGIS table for which I would only like the user to be able to select a pre-defined value.
Along with my table, I have created a separate PostGIS table listing out those values that I would like the user to be able to select. I filled out the options within the value relation widget for my layer, but have found that when I bring my table back into my project after saving it, I am unable to see any options in the drop down menu it shows (I saved my style when I set the value relation widget properties).
The error I get is regarding permission denied for the sequence (as I have a primary key field in my main table, although I have made sure the user has all access).
Just wondering what possible issues I might be having? Do I need my non spatial table in the project as well? I can provide any further information as required.
Thanks, Chris
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160718/e3dd4492/attachment.html>
