[Qgis-user] Value relation option in QGIS
Neumann, Andreas
a.neumann at carto.net
Mon Jul 18 04:21:37 PDT 2016
Hi Chris,
Yes - you need both tables in the QGIS project. I usually create a
separate group for the value list tables at the bottom of the layer
manager.
Andreas
On 2016-07-18 12:58, Chris Buckmaster wrote:
> Hi
> I have a field in a PostGIS table for which I would only like the user to be able to select a pre-defined value.
> Along with my table, I have created a separate PostGIS table listing out those values that I would like the user to be able to select. I filled out the options within the value relation widget for my layer, but have found that when I bring my table back into my project after saving it, I am unable to see any options in the drop down menu it shows (I saved my style when I set the value relation widget properties).
> The error I get is regarding permission denied for the sequence (as I have a primary key field in my main table, although I have made sure the user has all access).
> Just wondering what possible issues I might be having? Do I need my non spatial table in the project as well? I can provide any further information as required.
> Thanks, Chris
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160718/3bf97cda/attachment.html>
