[Qgis-user] Value relation option in QGIS
Chris Buckmaster
chris.buckmaster at runnymede.gov.uk
Mon Jul 18 04:41:56 PDT 2016
Hi Andreas
Yes I think the value map option might suit my needs better from what I can see, thanks very much for your response!
From: Neumann, Andreas [mailto:a.neumann at carto.net]
Sent: 18 July 2016 12:40
To: Chris Buckmaster
Cc: qgis-user at lists.osgeo.org
Subject: RE: [Qgis-user] Value relation option in QGIS
Hi Chris,
There is the "Value Map" alternative, which loads the value and descriptions from an existing layer and you can remove that value layer afterwards. The drawback is that it isn't a "live link". So if you change your value table you have to manually resync the data. The values and descriptions are then stored in the project and exported/loaded with the style.
There is a project just about to be started that more intelligently loads data from PostgreSQL (project generator). But this won't be available until 2017. Meanwhile, if your data is in PostgreSQL, you can also use the "Data driven input mask" plugin from Bernhard Ströbl - which does exactly that, but from a Python plugin.
Greetings,
Andreas
On 2016-07-18 13:28, Chris Buckmaster wrote:
Hi Andreas
Thanks for confirming – I think I understand your approach, but is there a way to store these values in the widget properties, perhaps under value map then so the separate table may not be required?
There will be occasions where a user will want to add the spatial layer from the PostGIS connection, but they wouldn't necessarily know that other tables need to be added as well which link to that.
Thanks
Sent: 18 July 2016 12:22
Cc: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Value relation option in QGIS
Hi Chris,
Yes - you need both tables in the QGIS project. I usually create a separate group for the value list tables at the bottom of the layer manager.
Andreas
On 2016-07-18 12:58, Chris Buckmaster wrote:
Hi
I have a field in a PostGIS table for which I would only like the user to be able to select a pre-defined value.
Along with my table, I have created a separate PostGIS table listing out those values that I would like the user to be able to select. I filled out the options within the value relation widget for my layer, but have found that when I bring my table back into my project after saving it, I am unable to see any options in the drop down menu it shows (I saved my style when I set the value relation widget properties).
The error I get is regarding permission denied for the sequence (as I have a primary key field in my main table, although I have made sure the user has all access).
Just wondering what possible issues I might be having? Do I need my non spatial table in the project as well? I can provide any further information as required.
Thanks, Chris
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160718/2cf857b7/attachment.html>
