[Qgis-user] environment variable
Matthias Kuhn
matthias at opengis.ch
Tue Jul 19 04:46:18 PDT 2016
You can also set it system wide:
http://www.nextofwindows.com/how-to-addedit-environment-variables-in-windows-7
if you only need the connection in QGIS you can easily go with adjusting
qgis.bat but if you also would like to access the DB from other programs
it's a good idea to set it on system level.
Matthias
On 19/07/16 12:48, Fuenfer-Koenigstein.Benjamin at swm.de wrote:
> Thanks a lot, worked great! Great solution for us to just change the
> qgis.bat after installation.
> Benjamin Fünfer-Königstein
> S-IP-AN-TG Techn. Geschäftsfelder
> *Von:*Blumentrath, Stefan [mailto:Stefan.Blumentrath at nina.no]
> *Gesendet:* Dienstag, 19. Juli 2016 11:33
> *An:* Fuenfer-Koenigstein.Benjamin S-IP-AN-TG; qgis-user at lists.osgeo.org
> *Betreff:* RE: environment variable
> Maybe it helps to add the declaration of that environment variable to
> the qgis.bat startup?
> Cheers
> Stefan
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160719/2ae55c6e/attachment.html>
