[Qgis-user] Using QGIS to create Geoserver SLD
Richard McDonnell
richard.mcdonnell at opw.ie
Tue Jul 19 04:48:40 PDT 2016
Hello all,
Ok, I have been looking at this for a while, and I think I have it
nailed down pretty well.
There has been some issues with using QGIS SLD's in Geoserver.
The following should enable you to utilise the styling power of QGIS and
make it compatible with Geoserver
In the main, this process only works for geometry, and will not work for
styling text it may require some additional tweaking here and there also.
Firstly, style your layer the way you want.
Next save your style as a SLD.
Open the SLD in Notepad++ or other text editor
Create a new blank text document and use the following as a template:
*/<?xml version="1.0" encoding="ISO-8859-1"?>/*
*/<StyledLayerDescriptor version="1.0.0" /*
*/xsi:schemaLocation="http://www.opengis.net/sld
StyledLayerDescriptor.xsd" /*
*/xmlns="http://www.opengis.net/sld" /*
*/xmlns:ogc="http://www.opengis.net/ogc" /*
*/xmlns:xlink="http://www.w3.org/1999/xlink" /*
*/xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">/*
*/<NamedLayer>/*
*/<Name>YourLayerName</Name>/*
*/<UserStyle>/*
*/<Title>YourLayerTitle</Title>/*
*/<FeatureTypeStyle>/*
*/<!-- Start -->/*
*/<!-- COPY AND PASTE QGIS SLD CODE BETWEEN <FeatureTypeStyle> and
</FeatureTypeStyle> IN HERE-->/*
*/<!-- End --> /*
*/</FeatureTypeStyle>/*
*/</UserStyle>/*
*/</NamedLayer>/*
*/</StyledLayerDescriptor>/*
Copy the code between but excluding <FeatureTypeStyle> and
</FeatureTypeStyle> and paste it into the new document overwriting
</FeatureTypeStyle> IN HERE--> /*
Find and replace the following:
·*/se:/* with nothing (effectively deleting it) so for example where you
have <se:Rule> it becomes <Rule>
·*/<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc"> /*with
*/<ogc:Filter>/*
·Delete all instances of */<Description>…..</Description>/* inclusive of
everything in between (usually a Title)
·*SvgParameter *with *CssParameter
One other thing where you utilise Map units (meters, feet or pixel) in
your styling you will have to use the following examples shown in the
link below
http://docs.geoserver.org/latest/en/user/styling/sld-extensions/uom.html
I would ask the question, would it be possible to create a simple
Geoserver Style using what I have found above?? adding an option to save
the QGIS style using the above rules?
If anyone has any questions or needs any clarification let me know, If I
can help I will.
Regards,
Richard McDonnell
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160719/cbb0496a/attachment.html>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160719/cbb0496a/attachment.vcf>
