[Qgis-user] Using QGIS to create Geoserver SLD
Richard McDonnell
richard.mcdonnell at opw.ie
Tue Jul 19 07:34:32 PDT 2016
Ok,
Not quite sure what you are looking for, but If I have your gist.
I have done some work on a OSM Dataset for Ireland, both styled in QGIS
and in Geoserver.
The dataset is stored as a PostGIS database and served on Geoserver. So
I would have examples of how I replicated styling on both.
I could provide a dump of the database, which also has the styling for
QGIS saved as a table, and a copy of the SLD files for Geoserver.
You may have some difficulty with the symbology though on the GeoServer
Side, even though I used QGIS Symbols we have them served centrally so
as they can be accessed by geoserver.
The SLD's for GeoServer where created a while ago, and I was still
learning so they may be a little messy. I also have little to no
experience in programming....
I could also give examples of other issues I have come across, along
with my solutions to these.
As a topic of discussion though, the biggest issue at present is labels,
QGIS SLD'd don't save labels, I found that to be the most tricky part of
styling to date. Also the use of attributes in the styling, for example,
having a text rotation and size attribute, I have examples of this
also, but wont be able to provide data, as its commercially sensitive
and we don't own the dataset ourselves.
I would welcome the opportunity to join the hackathon. Is there any
further details on this, Date, Time virtual access portal? Im afraid, I
would have to virtually attend.
Regards,
Richard.
On 19/07/2016 13:46, Luigi Pirelli wrote:
> Hi Richard
> can you prepare a test case that have to be solved pusching somewhere?
> I mean
> a
> 1) base layer
> 2) a workflow to have it in geoserver and qgis (a qgs project)
> 3) the expected rendering in QGIS and/or Geoserver (images)
> 4) specify versions for geoserver and qgis
> 5) any additional data (e.g sld or qml) with workflow to replicate
> your experience
> in this way you can help to target punctual problems if a general
> solution can't be found.
> As Richard said, please feel free to join to the "hackaton" in Bonn,
> remotely or live.
> cheers
> Luigi Pirelli
> * Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS:
> https://www.packtpub.com/application-development/mastering-qgis
> On 19 July 2016 at 13:48, Richard McDonnell <richard.mcdonnell at opw.ie
> <mailto:richard.mcdonnell at opw.ie>> wrote:
> Hello all,
> Ok, I have been looking at this for a while, and I think I have it
> nailed down pretty well.
> There has been some issues with using QGIS SLD's in Geoserver.
> The following should enable you to utilise the styling power of
> QGIS and make it compatible with Geoserver
> In the main, this process only works for geometry, and will not
> work for styling text it may require some additional tweaking here
> and there also.
> Firstly, style your layer the way you want.
> Next save your style as a SLD.
> Open the SLD in Notepad++ or other text editor
> Create a new blank text document and use the following as a template:
> */<?xml version="1.0" encoding="ISO-8859-1"?>/*
> */<StyledLayerDescriptor version="1.0.0" /*
> */xsi:schemaLocation="http://www.opengis.net/sld
> StyledLayerDescriptor.xsd"
> <http://www.opengis.net/sldStyledLayerDescriptor.xsd> /*
> */xmlns="http://www.opengis.net/sld" <http://www.opengis.net/sld> /*
> */xmlns:ogc="http://www.opengis.net/ogc"
> <http://www.opengis.net/ogc> /*
> */xmlns:xlink="http://www.w3.org/1999/xlink"
> <http://www.w3.org/1999/xlink> /*
> */xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> <http://www.w3.org/2001/XMLSchema-instance>>/*
> */<NamedLayer>/*
> */<Name>YourLayerName</Name>/*
> */<UserStyle>/*
> */<Title>YourLayerTitle</Title>/*
> */<FeatureTypeStyle>/*
> */<!-- Start -->/*
> */<!-- COPY AND PASTE QGIS SLD CODE BETWEEN <FeatureTypeStyle> and
> </FeatureTypeStyle> IN HERE-->/*
> */<!-- End --> /*
> */</FeatureTypeStyle>/*
> */</UserStyle>/*
> */</NamedLayer>/*
> */</StyledLayerDescriptor>/*
> Copy the code between but excluding <FeatureTypeStyle> and
> </FeatureTypeStyle> and paste it into the new document overwriting
> </FeatureTypeStyle> IN HERE--> /*
> Find and replace the following:
> ·*/se:/* with nothing (effectively deleting it) so for example
> where you have <se:Rule> it becomes <Rule>
> ·*/<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc"
> <http://www.opengis.net/ogc>> /*with */<ogc:Filter>/*
> ·Delete all instances of */<Description>…..</Description>/*
> inclusive of everything in between (usually a Title)
> ·*SvgParameter *with *CssParameter
> One other thing where you utilise Map units (meters, feet or
> pixel) in your styling you will have to use the following examples
> shown in the link below
> http://docs.geoserver.org/latest/en/user/styling/sld-extensions/uom.html
> I would ask the question, would it be possible to create a simple
> Geoserver Style using what I have found above?? adding an option
> to save the QGIS style using the above rules?
> If anyone has any questions or needs any clarification let me
> know, If I can help I will.
> Regards,
> Richard McDonnell
> OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
> OPW - Looking to the future - Caring for the past
> <http://www.opw.ie/>
> Email Disclaimer: http://www.opw.ie/en/disclaimer/
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
*_Richard McDonnell_*
*GIS Specialist PgD GIS AssocSCSI*
*OPW FRM Data Management*
*52 Stephens Green, Dublin 2.*
TEL: 01 6476543
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160719/3bffa516/attachment.html>
