[Qgis-user] EPSG of data from Manifold?
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Tue Jul 19 14:12:39 PDT 2016
Very cool!  Thanks for pointing that plugin out!!!!
Nicolas
On Jul 19, 2016 16:26, "Paolo Cavallini [via OSGeo.org]	" <ml-node+s1560n5277190h51 at n6.nabble.com> wrote:
have you tried the new plugin projestion? It may be of help in your case.
All the best. Il 19 luglio 2016 23:24:24 EEST, Bernd Vogelgesang < [hidden email] > ha scritto:
Am 19.07.2016, 21:53 Uhr, schrieb Nicolas Cadieux < [hidden email] >: I imagine you have tried
5243
4839
31491 to 31495? No, I haven't till now, cause I had no idea of them (the first 2) 5243 is the only one which does not end up in the Atlantic Ocean, but has an offset of around 200 km to the north ! So this seems to be the right direction ... investigating ... Thanx a lot Bernd
You could also look for Germany in https://epsg.io They have 129 CRS for Germany...
On Jul 19, 2016 15:27, "berndv. [via OSGeo.org]" < [hidden email] > wrote:
Am 19.07.2016, 21:19 Uhr, schrieb Nicolas Cadieux <<a href="/user/SendEmail.jtp?type&#61;node&amp;node&#61;5277180&amp;i&#61;0">[hidden email]>: Tried looking for it but no luck. It would help if you could say where the data is supposed to be.  Then you could try to look in www.epsg-registry.org .
Nicolas
Hi Nicolas, thanks a lot for trying. The shapes are situated around Gunzenhausen in Germany. Cheers Bernd On Jul 19, 2016 2:48 PM, "berndv. [via OSGeo.org]" <<a href="/user/SendEmail.jtp?type&#61;node&amp;node&#61;5277178&amp;i&#61;0">[hidden email]> wrote:
we just received some shapes accompanied by an xml and no prj.
So far I was out of luck finding the proper projection for this, but I'm
guessing that this stuff is from Manifold (my first contact with that)
Can anyone tell me from the xml what would be the related EPSG code for
this data?
<data>
        <coordinateSystem>
                <name>Orthographic</name>
                <datum>World Geodetic 1984 (WGS84)</datum>
                <system>Orthographic</system>
                <unit>Meter</unit>
                <majorAxis>6.378137000000000000000000e+006</majorAxis>
                <eccentricity>8.181919084262148600000000e-002</eccentricity>
                <centerX>0.000000000000000000000000e+000</centerX>
                <centerY>0.000000000000000000000000e+000</centerY>
                <centerZ>0.000000000000000000000000e+000</centerZ>
                <rotationX>0.000000000000000000000000e+000</rotationX>
                <rotationY>0.000000000000000000000000e+000</rotationY>
                <rotationZ>0.000000000000000000000000e+000</rotationZ>
                <scaleAdjustment>0.000000000000000000000000e+000</scaleAdjustment>
                <scaleX>1.000000000000000000000000e+000</scaleX>
                <localScaleX>3.175000000000070000000000e+000</localScaleX>
                <scaleY>1.000000000000000000000000e+000</scaleY>
                <localScaleY>3.175000000000070000000000e+000</localScaleY>
                <falseEasting>0.000000000000000000000000e+000</falseEasting>
                <localOffsetX>4.393181425000002600000000e+006</localOffsetX>
                <falseNorthing>0.000000000000000000000000e+000</falseNorthing>
                <localOffsetY>5.437772499999997200000000e+006</localOffsetY>
                <centerLat>0.000000000000000000000000e+000</centerLat>
                <centerLon>0.000000000000000000000000e+000</centerLon>
        </coordinateSystem>
</data>
Thanx a lot
Bernd
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
Qgis-user mailing list
<a href="/user/SendEmail.jtp?type&#61;node&amp;node&#61;5277175&amp;i&#61;0">[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
  If you reply to this email, your message will be added to the discussion below:
  http://osgeo-org.1560.x6.nabble.com/EPSG-of-data-from-Manifold-tp5277175.html
  To start a new topic under Quantum GIS - User, email <a href="/user/SendEmail.jtp?type&#61;node&amp;node&#61;5277180&amp;i&#61;1">[hidden email]
  To unsubscribe from Quantum GIS - User, <a href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro&#61;unsubscribe_by_code&amp;node&#61;4125267&amp;code&#61;bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg&#61;&#61;">click here.
  <a href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro&#61;macro_viewer&amp;id&#61;instant_html%21nabble%3Aemail.naml&amp;base&#61;nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&amp;breadcrumbs&#61;notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml" style="font:9px serif">NAML
View this message in context: Re: EPSG of data from Manifold?
Sent from the Quantum GIS - User mailing list archive  at Nabble.com. -- Bernd Vogelgesang Siedlerstraße 2 91083 Baiersdorf/Igelsdorf Tel: 09133-825374 _______________________________________________
<a href="/user/SendEmail.jtp?type&#61;node&amp;node&#61;5277180&amp;i&#61;2">[hidden email]
  http://osgeo-org.1560.x6.nabble.com/EPSG-of-data-from-Manifold-tp5277175p5277180.html
  To start a new topic under Quantum GIS - User, email [hidden email]
Sent from the Quantum GIS - User mailing list archive  at Nabble.com. -- Bernd Vogelgesang Siedlerstraße 2 91083 Baiersdorf/Igelsdorf Tel: 09133-825374 Qgis-user mailing list [hidden email] List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Paolo Cavallini
www.faunalia.eu _______________________________________________
[hidden email]
		http://osgeo-org.1560.x6.nabble.com/EPSG-of-data-from-Manifold-tp5277175p5277190.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/EPSG-of-data-from-Manifold-tp5277175p5277193.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160719/c48dd080/attachment.html>
