[Qgis-user] Zoom to cache level scales in QGIS
Neumann, Andreas a.neumann at carto.net
Wed Jul 20 07:21:44 PDT 2016
Just tested it and it doesn't seem to work with QuickMapService. It does
work if you connect through WMTS (WMS/WMTS connection).
QuickMapServices is a different technology and doesn't seem to support
the tile scale panel yet.
Andreas
On 2016-07-20 16:05, Chris Buckmaster wrote:
> Hi Andreas
> Thanks for that - I have added it but the slider is at the bottom of the menu and I cannot seem to move it up, do I move it manually or should the map zoom to the cached scale by just using my mouse wheel?
> I am using the Positron (retina) map from the CartoDB feed on QuickMapServices.
> Thanks
> FROM: Neumann, Andreas [mailto:a.neumann at carto.net]
> SENT: 20 July 2016 15:01
> TO: Chris Buckmaster
> CC: qgis-user at lists.osgeo.org
> SUBJECT: Re: [Qgis-user] Zoom to cache level scales in QGIS
> Hi Chris,
> Yes - see Menu --> View --> Panels --> Tile Scale Panel.
> Of course you need a tiled layer loaded in the project in order to enable it.
> Andreas
> On 2016-07-20 15:55, Chris Buckmaster wrote:
>> Hi
>> Is there a way that I am able to zoom to the specific zoom levels that a XYZ / WMTS service is cached at within QGIS?
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160720/2c7447c4/attachment.html>
