[Qgis-user] Zoom to cache level scales in QGIS
Chris Buckmaster
chris.buckmaster at runnymede.gov.uk
Wed Jul 20 07:22:43 PDT 2016
Ah no problem I will do it that way, thanks Andreas!
From: Neumann, Andreas [mailto:a.neumann at carto.net]
Sent: 20 July 2016 15:22
To: Chris Buckmaster
Cc: qgis-user at lists.osgeo.org
Subject: RE: [Qgis-user] Zoom to cache level scales in QGIS
Just tested it and it doesn't seem to work with QuickMapService. It does work if you connect through WMTS (WMS/WMTS connection).
QuickMapServices is a different technology and doesn't seem to support the tile scale panel yet.
Andreas
On 2016-07-20 16:05, Chris Buckmaster wrote:
Hi Andreas
Thanks for that – I have added it but the slider is at the bottom of the menu and I cannot seem to move it up, do I move it manually or should the map zoom to the cached scale by just using my mouse wheel?
I am using the Positron (retina) map from the CartoDB feed on QuickMapServices.
Thanks
Sent: 20 July 2016 15:01
Cc: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Zoom to cache level scales in QGIS
Hi Chris,
Yes - see Menu --> View --> Panels --> Tile Scale Panel.
Of course you need a tiled layer loaded in the project in order to enable it.
Andreas
On 2016-07-20 15:55, Chris Buckmaster wrote:
Hi
Is there a way that I am able to zoom to the specific zoom levels that a XYZ / WMTS service is cached at within QGIS?
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160720/8943b638/attachment.html>
