[Qgis-user] QGIS project not opening with WMS layer after exporting as PDF in print composer?
Chris Buckmaster chris.buckmaster at runnymede.gov.uk
Thu Jul 21 01:55:53 PDT 2016
Hi
I came across this problem before in a previous version but seem to be having the same issue in 2.16.0.
I have a project with a fairly simple PostGIS polygon layer and a WMS layer - I then use the print composer to compose a basic map, and then export it to a PDF. After saving the project and print composer, closing the project down and trying to re-open, the project opens, but the layers do not draw up and the 'Project loaded' message stays in the bottom left hand corner along with the blue status bar and does not move. I try to click on a layer and it goes to not responding.
Just wondering if anyone else has this problem? As mentioned it has happened in previous versions where I have exported PDFs with a WMS layer and then when I try to reopen the project it seems to fail.
Thanks, Chris
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160721/82f723ad/attachment.html>
