[Qgis-user] Bug in Map Composer?
Neumann, Andreas
a.neumann at carto.net
Mon Jul 25 00:22:49 PDT 2016
Hi Benjamin,
What projection are you using? Is the map extent on canvas and composer
exactly the same?
There are projections where scale varies according to the latitude of
the extent - but I rather assume it is a bug in QGIS and should be
reported in our issue tracker.
We would need sample data/project and steps to reproduce.
Thanks,
Andreas
On 2016-07-25 08:58, Benni wrote:
> David, thanks for your answer! The scale in map composer is definitely at
> 10,000 as I set it in the map-box item properties (numeric scale bar also
> prints 1:10,000). So the scale in composer is within the threshold of layer
> visibility. Besides that, as I said, the layer with "scale dependent
> visibility" set to min 1:10,001 and max 1:9,938 IS visible in map composer
> but IS NOT in the created pdf. Meanwhile I also found out that with WMS
> sources displayed in the map, there is a similar issue. The WMS is delivered
> with different styling at different scale levels. In map composer the style
> Looks the same as in the project canvas. But in a PDF printed from map
> composer, the styling looks different (like the one for smaller scales). So
> all together it still seems to be a bug. Anyone up to test it on your
> system? I can send the project and files I created for testing.
> Regards
> Benjamin
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Bug-in-Map-Composer-tp5277723p5277953.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160725/b1f3bd6a/attachment.html>
