[Qgis-user] Profiles in QGIS
    Nicolas Cadieux
    nicolas.cadieux at archeotec.ca
    Wed Jul 27 12:21:56 PDT 2016
I recommend you talk with the person responsible for the Qgis2treejs.  He has a lot of features that are not yet documented (at least the last time I used it).  He may have a scale bar.  That is a very good plugin.
I am still waiting for a good AutoCAD open source replacement also.
I see blender has been suggested and I use cloud compare.  Thats good but mainly for point cloud data.
Cheers
Nicolas
On Jul 27, 2016 14:39, "Tyler Veinot-2 [via OSGeo.org]	" <ml-node+s1560n5278431h22 at n6.nabble.com> wrote:
	Nicholas; Looking for more open source; AutoCAD is good but if I was to raise a PO I would go for Esri Standard and the Arc Scene extensions. Qgis2threejs, I think thats the right one, provides a very decent 3D render of a XYZ dataset, but it takes some processing power and I see no way to add a scale bar to the side to show elevations. What I am looking for is something like Esri's profile viewer, been a long time since I used it so that might not be the right name, where you draw a line, like a road centre line, and it shows you a profile view of the geometries along that line. I think you could even assign a width or buffer so that it would only return geometries within a certain distance of the line. It basically showed it as a graph and required very little processing power. Just trying to find something similar in QGIS or other open source product for our field operations and techs to use. Tyler On Wed, Jul 27, 2016 at 2:18 PM, Nicolas Cadieux < [hidden email] > wrote: Hi,
You may have to try a full 3D software for that.  AutoCAD??? I have not found a good 3D replacement for that.
Good luck
Nicolas
On Jul 27, 2016 13:06, "Tyler Veinot-2 [via OSGeo.org]	" < [hidden email] > wrote:
	Nicolas; Thank you, I have been experimenting with the grass tools quite a bit lately. I didn't include them because they are not a plugin as much as they are core function. I work mostly with vector layers i.e. pipe data so I am not so much interested in the DEM profile, although it would be good to see that too, as I am interested in showing the pipe profiles and how they intersect manholes/junctions. Tyler  On Wed, Jul 27, 2016 at 2:21 PM, Tyler Veinot <<a href="/user/SendEmail.jtp?type=node&node=5278415&i=0">[hidden email]> wrote: Nicolas; Thank you, I have been experimenting with the grass tools quite a bit lately. I didn't include them because they are not a plugin as much as they are core function. I work mostly with vector layers i.e. pipe data so I am not so much interested in the DEM profile, although it would be good to see that too, as I am interested in showing the pipe profiles and how they intersect manholes/junctions. Tyler  On Wed, Jul 27, 2016 at 12:54 PM, Nicolas Cadieux <<a href="/user/SendEmail.jtp?type=node&node=5278415&i=1">[hidden email]> wrote: Hi,
There is a simple plugin called "profile tool" that works well with raster data.  For cleaning data, Grass has good topology tools in the processing plugin.
Nicolas
On Jul 27, 2016 11:36, "Tyler Veinot-2 [via OSGeo.org]	" <<a href="http:///user/SendEmail.jtp?type=node&node=5278405&i=0">[hidden email]> wrote:
	Hi all; Anyone here use QGIS for a water and sewer utility that can suggest some good plugins for; structuring, processing, and/or cleaning data? Any plugin repositories that might be of interest to me? Also: Has anyone worked with profile views in QGIS? I tried a few plugins for viewing 3D datasets but I am interested to see what else is out there and/or is being worked on. Currently tried GHydraulics, mmqgis, networks, qgis_epanet, Qgis2threejs Thanks Tyler
Qgis-user mailing list
<a href="/user/SendEmail.jtp?type=node&node=5278402&i=0">[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/Profiles-in-QGIS-tp5278402.html
		To start a new topic under Quantum GIS - User, email <a href="/user/SendEmail.jtp?type=node&node=5278415&i=2">[hidden email]
		To unsubscribe from Quantum GIS - User, <a href=" http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg== ;">click here.
		<a href=" http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml " style="font:9px serif">NAML
View this message in context: Re: Profiles in QGIS
Sent from the Quantum GIS - User mailing list archive  at Nabble.com. _______________________________________________
<a href="/user/SendEmail.jtp?type=node&node=5278415&i=3">[hidden email]
<a href="/user/SendEmail.jtp?type=node&node=5278415&i=4">[hidden email]
		http://osgeo-org.1560.x6.nabble.com/Profiles-in-QGIS-tp5278402p5278415.html
		To start a new topic under Quantum GIS - User, email [hidden email]
[hidden email]
[hidden email]
		http://osgeo-org.1560.x6.nabble.com/Profiles-in-QGIS-tp5278402p5278431.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Profiles-in-QGIS-tp5278402p5278443.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160727/3aaa789c/attachment.html>
