[Qgis-user] Geosoft Grid Files
Benoit de Cabissole
benoit-3 at bc-consult.com
Thu Jul 28 00:36:55 PDT 2016
Although the .grd format used by Geosoft nowadays is proprietary, you
can use the free viewer, as said below, to export the file into .gxf
(the Geosoft grid exchange format) and open it in many, many
applications, including QGIS.
A word of caution: you must be sure that the orientation of the Geosoft
grid is set to 1, otherwise the GDAL GXF importer will not work
correctly (at least, as at the last time I've used it, long time ago!).
cheers,
Benoit
On 28/07/2016 04:44, Szilard Albert wrote:
> Hi, indeed, Oasis Montaj free viewer is able to convert .grd to .ers, from under Grids menu. I successfully exported a .grd file as .ers, and while my Qgis is busy processing, I was able to open the exported .ers in Global Mapper.
> Tried to attach a screenshot of the output format choices, but it gets blocked due to message size. regards, Szilard
> On 28 July 2016 at 11:45, Nicolas Cadieux <nicolas.cadieux at archeotec.ca> wrote:
> Hi,
> According to this the geosoft free viewer has some export capabilities.
> https://pubs.usgs.gov/of/2004/1258/Data/grid_facts.txt
> Good luck
> Nicolas
> On Jul 27, 2016 21:24, "Grant Boxer [via OSGeo.org]" <[hidden email] [1]> wrote:
> QGIS does not seem to be able to read the Geosoft grid format (*.grd) grids.
> Can anyone suggest how I may be able to convert these files to a format (for example to ERMapper (*.ers) files) suitable for QGIS?
> Grant Boxer
> Perth, Western Australia
> Qgis-user mailing list
> <a href="/user/SendEmail.jtp?type=node&node=5278481&i=0">[hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion below: http://osgeo-org.1560.x6.nabble.com/Geosoft-Grid-Files-tp5278481.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, <a href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg== [2];">click here.
> <a href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml [3]" style="font:9px serif">NAML
> View this message in context: Re: Geosoft Grid Files [4]
> Sent from the Quantum GIS - User mailing list archive [5] at Nabble.com.
Links:
[1] http:///user/SendEmail.jtp?type=node&node=5278482&i=0
[2]
http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node&%2361;4125267&code&%2361;bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg&%2361;&%2361
[3]
http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id&%2361;instant_html%21nabble%3Aemail.naml&base&%2361;nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs&%2361;notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml
[4]
http://osgeo-org.1560.x6.nabble.com/Geosoft-Grid-Files-tp5278481p5278482.html
[5] http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160728/2f187c8d/attachment.html>
