[Qgis-user] Profiles in QGIS
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Thu Jul 28 02:41:10 PDT 2016
Hi Tyler,
What type of 3D datasets are you working with? You mentioned sewer network, is it related to the, for example, water depth/level in pipe or on the ground with time element? If it is a temporal dataset of surface water you can probably look into Crayfish plugin. It has its own profile tool, where the profile gets updated as you browser through time.
Cheers
Saber
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Tyler Veinot
Sent: 27 July 2016 16:54
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Profiles in QGIS
Hi all;
Anyone here use QGIS for a water and sewer utility that can suggest some good plugins for; structuring, processing, and/or cleaning data? Any plugin repositories that might be of interest to me?
Also:
Has anyone worked with profile views in QGIS? I tried a few plugins for viewing 3D datasets but I am interested to see what else is out there and/or is being worked on.
Currently tried GHydraulics, mmqgis, networks, qgis_epanet, Qgis2threejs
Thanks
Tyler
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell pro
ducts, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160728/2c66bed4/attachment.html>
