[Qgis-user] Profiles in QGIS
    Tyler Veinot
    tylerkveinot at gmail.com
    Thu Jul 28 03:55:27 PDT 2016
All;
Thanks for the info and presentations I will look into them this evening.
If there are projects related specifically to water and sewer I might be
able to squeeze some coin out of management to help support the project.
Saber;
Not looking at temporal datasets at this time, just looking to see the
profiles of our pipes (Water and Sewer) and manholes and where they are in
relation to other buried infrastructure; not to say we wouldn't like to get
into more robust capabilities in the future. Crayfish sounds pretty capable
I will certainly take a look.
Tyler
On Thu, Jul 28, 2016 at 6:41 AM, Saber Razmjooei <
saber.razmjooei at lutraconsulting.co.uk> wrote:
> Hi Tyler,
> What type of 3D datasets are you working with? You mentioned sewer
> network, is it related to the, for example, water depth/level in pipe or on
> the ground with time element? If it is a temporal dataset of surface water
> you can probably look into Crayfish plugin. It has its own profile tool,
> where the profile gets updated as you browser through time.
> Cheers
> Saber
> *From:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf
> Of *Tyler Veinot
> *Sent:* 27 July 2016 16:54
> *To:* qgis-user at lists.osgeo.org
> *Subject:* [Qgis-user] Profiles in QGIS
> Hi all;
> Anyone here use QGIS for a water and sewer utility that can suggest some
> good plugins for; structuring, processing, and/or cleaning data? Any plugin
> repositories that might be of interest to me?
> Also:
> Has anyone worked with profile views in QGIS? I tried a few plugins for
> viewing 3D datasets but I am interested to see what else is out there
> and/or is being worked on.
> Currently tried GHydraulics, mmqgis, networks, qgis_epanet, Qgis2threejs
> Thanks
> Tyler
> This email and any files transmitted with it are confidential and intended
> solely for the use of the individual or entity to whom they are addressed.
> If you have received this email in error please notify the system manager.
> This message contains confidential information and is intended only for the
> individual named. If you are not the named addressee you should not
> disseminate, distribute or copy this e-mail. Please notify the sender
> immediately by e-mail if you have received this e-mail by mistake and
> delete this e-mail from your system. If you are not the intended recipient
> you are notified that disclosing, copying, distributing or taking any
> action in reliance on the contents of this information is strictly
> prohibited.
> Whilst reasonable care has been taken to avoid virus transmission, no
> responsibility for viruses is taken and it is your responsibility to carry
> out such checks as you feel appropriate.
> If this email contains a quote or offer to sell products, carry out work
> or perform services then our standard terms and conditions
> <http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf>
> shall apply unless explicitly stated otherwise.
> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160728/98df914b/attachment.html>
