[Qgis-user] Fusion of Data Tables
    Nicolas Cadieux
    nicolas.cadieux at archeotec.ca
    Tue Nov  1 15:12:23 PDT 2016
Google for "one to many relation".  You should find something in the project properties also.
Nicolas
> Le 1 nov. 2016 à 16:15, Jeffrey.Rhodes [via OSGeo.org] <ml-node+s1560n5293824h5 at n6.nabble.com> a écrit :
> Hello,
> I was using QGIS to set up a new information/navigation system for my university, when I came across this problem:
> I got different data sets from different sources, one that has all the buildings in it , and one with specific rooms in buildings.
> When I tried to fuse the two data sets I had the problem that one list has multiple entries per adress/building (multiple noticeable rooms in a building), while the other only had one entry per building, for the basic building geometry. Upon connecting them it always only connected the first entry in the room list to the building, ignoring the others.
> Is there any way or plug in to fix that? E.g. Something to create multiple entries of the houses table, or put the rooms into multiple columns for each building?
> Thanks in advance
> Jeffrey
> Qgis-user mailing list
> [hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Fusion-of-Data-Tables-tp5293824.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Fusion-of-Data-Tables-tp5293824p5293839.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161101/5be97fc7/attachment.html>
