[Qgis-user] Fusion of Data Tables
Alexandre Neto
senhor.neto at gmail.com
Tue Nov 1 23:45:23 PDT 2016
Check the user's manual:
http://docs.qgis.org/2.14/en/docs/user_manual/working_with_vector/attribute_table.html?highlight=relations#id11
Alexandre Neto
A ter, 1/11/2016, 22:12, Nicolas Cadieux <nicolas.cadieux at archeotec.ca>
escreveu:
> Hi,
> Google for "one to many relation". You should find something in the
> project properties also.
> Nicolas
> Le 1 nov. 2016 à 16:15, Jeffrey.Rhodes [via OSGeo.org] <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5293839&i=0>> a écrit :
> Hello,
> I was using QGIS to set up a new information/navigation system for my
> university, when I came across this problem:
> I got different data sets from different sources, one that has all the
> buildings in it , and one with specific rooms in buildings.
> When I tried to fuse the two data sets I had the problem that one list has
> multiple entries per adress/building (multiple noticeable rooms in a
> building), while the other only had one entry per building, for the basic
> building geometry. Upon connecting them it always only connected the first
> entry in the room list to the building, ignoring the others.
> Is there any way or plug in to fix that? E.g. Something to create multiple
> entries of the houses table, or put the rooms into multiple columns for
> each building?
> Thanks in advance
> Jeffrey
> Qgis-user mailing list
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5293824&i=0>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/Fusion-of-Data-Tables-tp5293824.html
> To start a new topic under Quantum GIS - User, email [hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5293839&i=1>
> To unsubscribe from Quantum GIS - User, click here.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: Fusion of Data Tables
> <http://osgeo-org.1560.x6.nabble.com/Fusion-of-Data-Tables-tp5293824p5293839.html>
> Sent from the Quantum GIS - User mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
> Nabble.com.
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161102/8eae9c2d/attachment.html>
