[Qgis-user] Corporate Users
Richard Duivenvoorde rdmailings at duif.net
Sat Nov 5 02:06:03 PDT 2016
Bo: thanks for this great write up!
Is it ok if you/I write a small article on blog.qgis.org or qgis.nl or
qgis.dk and point to the english version of your writeup?
https://github.com/Frederikssund/Alternativ-QGIS-installation/blob/master/Readme%20-%20english.md
I think a lot of organisations/windows system admins will be greatfull
to you!
By the way, in my view the default storing mechanism of settings should
be ini file based anyway! I'll try to bring this up on the dev list again.
Regards,
On 04-11-16 15:36, Bo Victor Thomsen wrote:
> We ( as in the municipality of Frederikssund, Denmark) has a medium size
> enterprise installation of Qgis 2.8 at around 100 local installations of
> Qgis 2.8 in a Windows-7 64 bit environment. There is no significant
> problems with this installation.
> The largest problem by far was to sift through a mountain sized heap of
> tab files from an older installation of MapInfo and determine which
> should be restructured, cleaned and  imported to our MS-SQLServer based
> database environment.
> In the near future - probably a month - We are doing a roll out of Qgis
> 2.18 to around 250 Windows workstations using this method:
> "https://github.com/Frederikssund/Alternativ-QGIS-installation" (don't
> worry about the Danish readme.md - there is documentation in English too
> If you have a large amount of different layers / tables, I suggest you
> take a look at the "QLR Browser" plugin. This plugin provides an immense
> help to structure user access to a large number of layers:
> And of course: Use a database to store your data. Preferably
> Postgres/PostGIS (Open source and IMHO the most powerful spatial
> database), but MS-SQL Server or Oracle will do If you don't have a
> choice regarding database systems.
> Regards
> Bo Victor Thomsen
> GIS & Database specialist
> Municipality of Frederikssund
> Den 04/11/16 kl. 04:24 skrev Grant Boxer:
>> I am using QGIS in a single stand-alone situation and I was wondering
>> what examples there are of medium to large corporations using QGIS as
>> their GIS platform and what issues you need to be aware of in large
>> multi-user QGIS situations?
>> Grant Boxer
>> Perth, Western Australia
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
