[Qgis-user] Corporate Users
Régis Haubourg
regis.haubourg at gmail.com
Mon Nov 7 04:23:30 PST 2016
Post installing works, I had the case on one server where we forgot to
install MSVC++ before unzipping QGIS.
I've also eard of some packaging msvc dll's inside qgis package, but I
haven't tested that by myself
Cheers
Régis
2016-11-07 13:05 GMT+01:00 <Burghardt.Scholle at stadt.wolfsburg.de>:
> Hi Bo,
> first - thank you for pointing us to your great instructions. I have
> another question about this. I often have the problem, that on a fresh
> Windows installation the Microsoft C++ Redistributable environment lacks.
> Does your setup routine consider this? And will the environment be possibly
> automatically post-installed?
> Regards
> Burghardt
> > -----Ursprüngliche Nachricht-----
> > Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von
> > Bo Victor Thomsen
> > Gesendet: Samstag, 5. November 2016 19:30
> > An: qgis-user at lists.osgeo.org
> > Betreff: Re: [Qgis-user] Corporate Users
> > Hi Richard -
> > Be my guest, knock yourself out, go ahead - It's always nice if other
> people
> > can use the work that was invested in this project ;-)
> > I haven't too much time to spare the next month or two, so you have my
> full
> > permission to write an article about this method. I can of course help
> you by
> > "proof" reading the article before publishing if you find it necessary.
> > And I agree fully with you about using an ini file based approach to save
> > settings for Qgis :-)
> > Regards
> > Bo Victor
> > Den 05/11/16 kl. 10:06 skrev Richard Duivenvoorde:
> > > Bo: thanks for this great write up!
> > > Is it ok if you/I write a small article on blog.qgis.org or qgis.nl or
> > > qgis.dk and point to the english version of your writeup?
> > > https://github.com/Frederikssund/Alternativ-QGIS-installation/blob/mas
> > > ter/Readme%20-%20english.md
> > > I think a lot of organisations/windows system admins will be greatfull
> > > to you!
> > > By the way, in my view the default storing mechanism of settings
> > > should be ini file based anyway! I'll try to bring this up on the dev
> list again.
> > > Regards,
> > > On 04-11-16 15:36, Bo Victor Thomsen wrote:
> > >> We ( as in the municipality of Frederikssund, Denmark) has a medium
> > >> size enterprise installation of Qgis 2.8 at around 100 local
> > >> installations of Qgis 2.8 in a Windows-7 64 bit environment. There is
> > >> no significant problems with this installation.
> > >> The largest problem by far was to sift through a mountain sized heap
> > >> of tab files from an older installation of MapInfo and determine
> > >> which should be restructured, cleaned and imported to our
> > >> MS-SQLServer based database environment.
> > >> In the near future - probably a month - We are doing a roll out of
> > >> Qgis
> > >> 2.18 to around 250 Windows workstations using this method:
> > >> "https://github.com/Frederikssund/Alternativ-QGIS-installation"
> > >> (don't worry about the Danish readme.md - there is documentation in
> > >> English too
> > >> If you have a large amount of different layers / tables, I suggest
> > >> you take a look at the "QLR Browser" plugin. This plugin provides an
> > >> immense help to structure user access to a large number of layers:
> > >> And of course: Use a database to store your data. Preferably
> > >> Postgres/PostGIS (Open source and IMHO the most powerful spatial
> > >> database), but MS-SQL Server or Oracle will do If you don't have a
> > >> choice regarding database systems.
> > >> Regards
> > >> Bo Victor Thomsen
> > >> GIS & Database specialist
> > >> Municipality of Frederikssund
> > >> Den 04/11/16 kl. 04:24 skrev Grant Boxer:
> > >>> I am using QGIS in a single stand-alone situation and I was
> > >>> wondering what examples there are of medium to large corporations
> > >>> using QGIS as their GIS platform and what issues you need to be
> > >>> aware of in large multi-user QGIS situations?
> > >>> Grant Boxer
> > >>> Perth, Western Australia
> > >>> _______________________________________________
> > >>> Qgis-user mailing list
> > >>> Qgis-user at lists.osgeo.org
> > >>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > >>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161107/c5bc7677/attachment.html>
