[Qgis-user] Corporate Users
    Burghardt.Scholle at stadt.wolfsburg.de
    Mon Nov  7 04:05:36 PST 2016
Hi Bo,
first - thank you for pointing us to your great instructions. I have another question about this. I often have the problem, that on a fresh Windows installation the Microsoft C++ Redistributable environment lacks. Does your setup routine consider this? And will the environment be possibly automatically post-installed?
Regards
Burghardt
> -----Ursprüngliche Nachricht-----
> Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von
> Bo Victor Thomsen
> Gesendet: Samstag, 5. November 2016 19:30
> An: qgis-user at lists.osgeo.org
> Betreff: Re: [Qgis-user] Corporate Users
> Hi Richard -
> Be my guest, knock yourself out, go ahead - It's always nice if other people
> can use the work that was invested in this project ;-)
> I haven't too much time to spare the next month or two, so you have my full
> permission to write an article about this method. I can of course help you by
> "proof" reading the article before publishing if you find it necessary.
> And I agree fully with you about using an ini file based approach to save
> settings for Qgis :-)
> Regards
> Bo Victor
> Den 05/11/16 kl. 10:06 skrev Richard Duivenvoorde:
> > Bo: thanks for this great write up!
> > Is it ok if you/I write a small article on blog.qgis.org or qgis.nl or
> > qgis.dk and point to the english version of your writeup?
> > https://github.com/Frederikssund/Alternativ-QGIS-installation/blob/mas
> > ter/Readme%20-%20english.md
> > I think a lot of organisations/windows system admins will be greatfull
> > to you!
> > By the way, in my view the default storing mechanism of settings
> > should be ini file based anyway! I'll try to bring this up on the dev list again.
> > Regards,
> > On 04-11-16 15:36, Bo Victor Thomsen wrote:
> >> We ( as in the municipality of Frederikssund, Denmark) has a medium
> >> size enterprise installation of Qgis 2.8 at around 100 local
> >> installations of Qgis 2.8 in a Windows-7 64 bit environment. There is
> >> no significant problems with this installation.
> >> The largest problem by far was to sift through a mountain sized heap
> >> of tab files from an older installation of MapInfo and determine
> >> which should be restructured, cleaned and  imported to our
> >> MS-SQLServer based database environment.
> >> In the near future - probably a month - We are doing a roll out of
> >> Qgis
> >> 2.18 to around 250 Windows workstations using this method:
> >> "https://github.com/Frederikssund/Alternativ-QGIS-installation"
> >> (don't worry about the Danish readme.md - there is documentation in
> >> English too
> >> If you have a large amount of different layers / tables, I suggest
> >> you take a look at the "QLR Browser" plugin. This plugin provides an
> >> immense help to structure user access to a large number of layers:
> >> And of course: Use a database to store your data. Preferably
> >> Postgres/PostGIS (Open source and IMHO the most powerful spatial
> >> database), but MS-SQL Server or Oracle will do If you don't have a
> >> choice regarding database systems.
> >> Regards
> >> Bo Victor Thomsen
> >> GIS & Database specialist
> >> Municipality of Frederikssund
> >> Den 04/11/16 kl. 04:24 skrev Grant Boxer:
> >>> I am using QGIS in a single stand-alone situation and I was
> >>> wondering what examples there are of medium to large corporations
> >>> using QGIS as their GIS platform and what issues you need to be
> >>> aware of in large multi-user QGIS situations?
> >>> Grant Boxer
> >>> Perth, Western Australia
> >>> _______________________________________________
> >>> Qgis-user mailing list
> >>> Qgis-user at lists.osgeo.org
> >>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> >>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
