[Qgis-user] Feedback re future of core c++ plugins in QGIS 3.0
    Nicolas Cadieux
    nicolas.cadieux at archeotec.ca
    Mon Nov  7 18:49:13 PST 2016
Hi Nyall,
Very interesting.  I have a few comments. Where would go If I wanted to encourage more the development of the the new raster calculator for qgis 3 (one that is  multithreaded, GPU enabled and huge raster ready)? This is a real game stopper for using qgis with Lidar data.   I have help with the bugs but can I do more?
I see that lots of stuff below is moved to the processing plugin. I have been continually having problems with this in a multiple user environment where I am stuck deleting the processing plugin folder for every user in a machine every time I do an install.  That means that if 6 users have use a single machine, I need to delete the processing folder 6 times as more often then not, I end up with old and new versions of the processing algorithms on the same computer.  Are you planing to change this or to have some kind of version checker when a users run Qgis after an update?
It also would be nice to do QGIS update from within QGIS and the option to export QGIS to a USB key (without having to change a big bunch of variables). That would make it easier for I user that do not have admin rights.
Nicolas
> Le 7 nov. 2016 à 20:24, Nyall Dawson [via OSGeo.org] <ml-node+s1560n5294735h46 at n6.nabble.com> a écrit :
> Hi all,
> Discussion is currently underway concerning the future of a number of
> the plugins which come preinstalled with QGIS.
> This concerns the plugins:
> - coordinate capture
> - evis
> - geometry_checker
> - georeferencer
> - heatmap
> - interpolation
> - offline editing
> - oracle raster
> - raster terrain analysis
> - road graph
> - spatial query
> - topology checker
> If you're an active user of any of these plugins, your feedback would
> be greatly appreciated. You can join the discussion over at:
> https://github.com/qgis/qgis3.0_api/issues/67
> Note that a number of preinstalled plugins have already been removed
> in 3.0 - specifically:
> - geometry snapper: was generalised to work with all layer types and
> moved to a processing algorithm
> - zonal statistics: was moved to a processing algorithm
> - dxf2shp converter: was removed from QGIS - this conversion is better
> handled outside of QGIS, eg by using OGR tools directly.
> Nyall
> Qgis-user mailing list
> [hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Feedback-re-future-of-core-c-plugins-in-QGIS-3-0-tp5294735.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Feedback-re-future-of-core-c-plugins-in-QGIS-3-0-tp5294735p5294737.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161107/1153119b/attachment.html>
