[Qgis-user] Processing versioning (was: Feedback re future of core c++ plugins in QGIS 3.0)
Paolo Cavallini
cavallini at faunalia.it
Mon Nov 7 22:59:42 PST 2016
Hi Nicolas,
Il 08/11/2016 03:49, Nicolas Cadieux ha scritto:
> I see that lots of stuff below is moved to the processing plugin. I have
> been continually having problems with this in a multiple user
> environment where I am stuck deleting the processing plugin folder for
> every user in a machine every time I do an install. That means that if
> 6 users have use a single machine, I need to delete the processing
> folder 6 times as more often then not, I end up with old and new
> versions of the processing algorithms on the same computer. Are you
> planing to change this or to have some kind of version checker when a
> users run Qgis after an update?
agreed, it's a known annoying problem, that hits many users.
IMHO a warning "You have installed an older version - do you want to
uninstall and use the latest?" would be enough.
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
