[Qgis-user] Creating parent feature with geometry from child feature
    Nicolas Boisteault
    boisteault at observatoire-environnement.org
    Fri Nov 11 04:41:20 PST 2016
Hi Nyall,
Thank you for this fix.
I'm on windows so I guess I have to wait for this fix to be merged then
download master. Am I right?
Will it be in qgis-dev or qgis-rel-dev or both?
Le 2016-11-09 07:57, Nyall Dawson a écrit :
> On 9 November 2016 at 16:26, Neumann, Andreas <a.neumann at carto.net> wrote:
>> Hi Nicolas,
>> We have similar issues in our projects.
>> It looks like a bug to me that the default value is called that many times.
>> Matthias: any comments on that? Or can you explain why this happens and how
>> this can be potentially fixed?
> It's (probably) fixed with https://github.com/qgis/QGIS/pull/3733 [1], but
> testing & confirmation would be good!
> Nyall
>> Greetings,
>> Andreas
>> On 2016-11-08 17:50, Nicolas Boisteault wrote:
>> Logs confirm the issue :
>> First time form opened :
>> 2016-11-08 17:45:03 CET [15733-1] user at carto LOG: statement: SELECT
>> nextval('public.station_gid_seq'::regclass)
>> 2016-11-08 17:45:03 CET [15733-2] user at carto LOG: statement: SELECT
>> 2016-11-08 17:45:03 CET [15733-3] user at carto LOG: statement: SELECT
>> 2016-11-08 17:45:03 CET [15733-4] user at carto LOG: statement: SELECT
>> 2016-11-08 17:45:03 CET [15733-5] user at carto LOG: statement: SELECT
>> 2016-11-08 17:45:03 CET [15733-6] user at carto LOG: statement: SELECT
>> 2016-11-08 17:45:03 CET [15733-7] user at carto LOG: statement: SELECT
>> 2016-11-08 17:45:03 CET [15733-8] user at carto LOG: statement: SELECT
>> 2016-11-08 17:45:03 CET [15733-9] user at carto LOG: statement: SELECT
>> 2016-11-08 17:45:03 CET [15733-10] user at carto LOG: statement: SELECT
>> 2016-11-08 17:45:03 CET [15733-11] user at carto LOG: statement: SELECT
>> Second time form opened :
>> 2016-11-08 17:47:10 CET [15733-48] user at carto LOG: statement: SELECT
>> 2016-11-08 17:47:10 CET [15733-49] user at carto LOG: statement: SELECT
>> 2016-11-08 17:47:10 CET [15733-50] user at carto LOG: statement: SELECT
>> 2016-11-08 17:47:10 CET [15733-51] user at carto LOG: statement: SELECT
>> 2016-11-08 17:47:10 CET [15733-52] user at carto LOG: statement: SELECT
>> 2016-11-08 17:47:10 CET [15733-53] user at carto LOG: statement: SELECT
>> 2016-11-08 17:47:10 CET [15733-54] user at carto LOG: statement: SELECT
>> 2016-11-08 17:47:10 CET [15733-55] user at carto LOG: statement: SELECT
>> 2016-11-08 17:47:10 CET [15733-56] user at carto LOG: statement: SELECT
>> 2016-11-08 17:47:10 CET [15733-57] user at carto LOG: statement: SELECT
>> 2016-11-08 17:47:10 CET [15733-58] user at carto LOG: statement: SELECT
>> If someone can confirm this issue I'll open a ticket.
>> Le 2016-11-08 17:27, Nicolas Boisteault a écrit :
>> What is weird is that every time I open the form it increments sequence of
>> 11 not 1. So I guess nextval is called 11 times! I'll try to log that. I'm
>> using QGIS 2.18.
>> Le 2016-11-08 16:35, Matthias Kuhn a écrit :
>> Yes, every time you open a form, a new gid is retrieved (nextval is
>> executed) what makes the counter go up very fast.
>> Another thing that could need some attention (it might have changed with
>> https://github.com/qgis/QGIS/pull/3733 [1] but I didn't check in detail).
>> Matthias
>> On 11/08/2016 04:19 PM, Nicolas Boisteault wrote:
>> Matthias,
>> Thank you for the tip.
>> It works without transactional editing.
>> I enabled it to test and I like the fact that observation layer is
>> automatically put in editable state when I put station layer as
>> editable. It is very convenient for users. I'll modify the foreign
>> key constraint and will tell if it works for me.
>> Now I have an issue which is not related to transactional editing. When
>> I create a new station the gid parameter is incremented by +11 not +1.
>> Can anyone confirm this issue? Thanks.
>> Le 2016-11-08 14:44, Matthias Kuhn a écrit :
>> Nicolas,
>> Sorry I forgot: you will probably also need to enable transactional
>> editing and set the foreign key constraint check to deferred to make it
>> work properly.
>> Regards
>> Matthias
>> On 11/08/2016 02:08 PM, Nicolas Boisteault wrote:
>> This is perfect! Thank you very much Matthias.
>> Le 2016-11-08 12:45, Matthias Kuhn a écrit :
>> Go to the project properties and on the data sources tab check "evaluate
>> default values on provider side".
>> Regards
>> Matthias
>> On 11/08/2016 12:37 PM, Nicolas Boisteault wrote:
>> Hi Matthias Kuhn,
>> First thank you very much for your help and your work on this feature
>> There is room for improvement but this functionality is already great
>> as it.
>> Another question. I also tried to add a station and an observation from
>> the station form.
>> When creating, I have 'nextval('public.station_gid_seq'::regclass)' in
>> the gid attribute and in the id_station attribute too which is good
>> to me.
>> Now if i save the observation feature first it won't work because the
>> station feature it refers doesn't exist. It is logical to me.
>> But if save the new station feature, it only save this feature and not
>> the relative observation with the newly foreign created.
>> Is it a bug or a limitation? Thanks.
>> Le 2016-11-08 12:09, Matthias Kuhn a écrit :
>> Hi Nicolas,
>> This is a limitation of the current implementation.
>> You can either add a new station without geometry first and then
>> select
>> it in the attribute table and use the add part tool to add a geometry.
>> Or add it from its own layer and then link it to the parent
>> observation.
>> I agree there is room for improvement.
>> Regards
>> Matthias
>> On 11/08/2016 11:49 AM, Nicolas Boisteault wrote:
>> Hi List,
>> I have two tables :
>> * station : gid, geom (point)
>> * observation : id, id_station (foreign key)
>> There is a 1:N relation; for one station feature there are multiple
>> observation features.
>> I add the relation between my two tables in QGIS -> project
>> properties.
>> I use the relation reference widget on id_station and check 'able the
>> add of new entities' (not sure about my english translation)
>> So now when I create a new observation I can click the plus symbol to
>> add a station but I can't see how I can create the point
>> geometry. I'm
>> not able to click the map.
>> Any hint? Thank you all.
>> Nicolas BOISTEAULT
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> <mailto:Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>>
>> <mailto:Qgis-user at lists.osgeo.org>>>
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user [2]
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user [2]
>> <mailto:Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>>>
Links:
[1] https://github.com/qgis/QGIS/pull/3733
[2] http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161111/4d62e25e/attachment.html>
