[Qgis-user] Geojson URL's
Pasquale Di Donato pasquale.didonato at gmail.com
Sat Nov 12 04:45:03 PST 2016
Hi Phil,
if you are under a proxy you have to set a GDAL variable:
Settings --> Options --> System --> Environment --> Add a variable
GDAL_HTTPS_PROXY and put your proxy:port in "Value"
Hope helps,
Pasquale
On Sat, Nov 12, 2016 at 7:50 AM, Phil (The Geek) Wyatt <
phil at wyatt-family.com> wrote:
> Hi Folks,
> I have access to some dynamic geojson URL's however I cannot get QGIS to
> accept them. They are in the following format
> https://*myorganisation*.org.au/other/gis/get.geojson?filter[
> members][group][]=2337
> If I paste this into a web browser , (with the correct organisation!) I
> get a valid geojson file that I can save and use in QGIS however I want to
> use it dynamically via a URL
> I get the error
> *Invalid Data Source: *https://myorganisation.org.au/
> other/gis/get.geojson?filter[members][group][]=2337 is not a valid or
> recognized data source
> I suspect it's something to do with authentication but I can't seem to get
> that working either.
> Any clues appreciated
> Cheers - Phil
> Kiva Lender <http://www.kiva.org/lender/phil80199001>, Thin Green Line
> Supporter <http://www.thingreenline.org.au/>, Volunteer Mapper (GISMO) - Red
> Cross <http://www.redcross.org.au/volunteering.aspx>, Wildcare Volunteer
> <http://wildcaretas.org.au/branches/friends-of-gis/>
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161112/3c581f82/attachment.html>
