[Qgis-user] different buffer for the same field
Marco Grisolia
marco.grisolia5 at gmail.com
Wed Nov 16 00:22:18 PST 2016
If you want to assign a specified buffer for each kind of feature, you
may use a simple PyQGIS script using a call of buffer() from
QgsGeometry(). Are you able to do it? Otherwise I may try to write it
for you if my understanding of the problem was right.
Therefore, if your buffer distances are inside a field, you may use
the "Variable Distance Buffer" algorithm from Processing.
Best regards,
Marco
2016-11-16 1:26 GMT+01:00 Azzurra Lentini <azzurralentini at gmail.com>:
> Dear all,
> I have a shape file with a field called “type”. In the “type” field I have
> 4 kinds of samples ( 19 records).
> See in the attachment.
> The 4 samples are: normal fault, inverse fault, overthrust, syncline.
> I would like to create a buffer with different distance for each sample (the
> best it would be to obtain a shape with 5 different buffer distances).
> For example the buffer distance for the sample “ normal fault” is 30 m, for
> the “inverse fault “ is 20 m, for the “overthrust” is 50 m and for the
> “syncline” is 20 m.
> How I can do this kind of buffer??
> Thanks A.L.
> Dr. Hydrogeologist
> AZZURRA LENTINI
> Expert of evaluation environmental hazards
> GIS application
> Haity Mobile Tel: 0050946057393
> Italy Mobile Tel.: **(39) 338 24 40 676
> SKYPE azzurrahydro
> *Par respect pour l'environnement,*
> *n'imprimez ce mail qu'en cas d'absolue nécessité*
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
