[Qgis-user] different buffer for the same field
    Azzurra Lentini
    azzurralentini at gmail.com
    Sun Nov 27 09:54:57 PST 2016
Dear Marco, apologies to write you only now.
Yes with variable distance buffer is fine. Thanks a lot.
If you can, could you please write me the PyQgis script for the other
option?
all regards, Azzurra
2016-11-16 9:22 GMT+01:00 Marco Grisolia <marco.grisolia5 at gmail.com>:
> If you want to assign a specified buffer for each kind of feature, you
> may use a simple PyQGIS script using a call of buffer() from
> QgsGeometry(). Are you able to do it? Otherwise I may try to write it
> for you if my understanding of the problem was right.
> Therefore, if your buffer distances are inside a field, you may use
> the "Variable Distance Buffer" algorithm from Processing.
> Best regards,
> Marco
> 2016-11-16 1:26 GMT+01:00 Azzurra Lentini <azzurralentini at gmail.com>:
> > Dear all,
> > I have a shape file with a field called “type”.  In the “type”  field I
> have
> > 4 kinds of samples ( 19 records).
> > See in the attachment.
> > The 4 samples are: normal fault, inverse fault, overthrust, syncline.
> > I would like to create a buffer with different distance for each sample
> (the
> > best it would be to obtain a shape with 5 different buffer distances).
> > For example  the buffer distance for the sample “ normal fault” is 30 m,
> for
> > the “inverse fault “ is 20 m, for the “overthrust” is 50 m and for the
> > “syncline” is 20 m.
> > How I can do this kind of buffer??
> > Thanks A.L.
> > Dr. Hydrogeologist
> > AZZURRA LENTINI
> > Expert of evaluation environmental hazards
> > GIS application
> > Haity Mobile Tel: 0050946057393
> > Italy Mobile Tel.: **(39) 338 24 40 676
> > SKYPE azzurrahydro
> > *Par respect pour l'environnement,*
> > *n'imprimez ce mail qu'en cas d'absolue nécessité*
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Dr. Hydrogeologist
AZZURRA LENTINI
GIS application
SKYPE azzurrahydro
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161127/4c721ce1/attachment.html>
