[Qgis-user] Editing a Postgis view
    Andrea Peri
    aperi2007 at gmail.com
    Wed Nov 16 00:39:23 PST 2016
Hi Matthias,
thx for response.
So the trouble is in my db.
Now I try to understand better why it is not working.
This is my actual try test:
create table schemaapp.repository(
 ID serial primary key NOT NULL,
 UUID varchar(50) NOT NULL,
 PROGETTO varchar(9) NOT NULL,
 PROCEDIMENTO text NOT NULL,
 GEOMETRIA1 geometry(MULTIPOINT, 3003)
create view schemaapp.v_repository_point as
 select
  a.id as id,
  a.uuid as uuid,
  a.progetto as progetto,
  a.procedimento as procedimento,
  a.geometria1 as geometria
from
  schemappa.repository_wfs as a
where
  a.geometria1 is not null;
I will know if discover something.
thx again.
2016-11-16 8:54 GMT+01:00 Matthias Kuhn <matthias at opengis.ch>:
> Hi Andrea,
> It works here.
> Do you have an instead of insert rule written on your view?
> It works for me this way (but my views are too complicated for postgres
> to create default insert rules by default anyway).
> You can also try to alter your view with a default value for the column
> in question.
> Best regards
> Matthias
> On 11/16/2016 08:15 AM, Andrea Peri wrote:
>> Hi,
>> I'm having some trouble to edit a postgis view using qgis.
>> The view is a simple:
>> select list-of-field from table1;
>> And the table1 is a table with a Primary key on a serial type field.
>> I add the first record and all was ok. The commit too.
>> When go to add the second record.
>> I start to have trouble.
>> The qgis report my always a constraint violation of the pk.
>> I try to leave the pk field empty, or try to fill it with a value.
>> No solution work.
>> So my question is if is confirmed that qgis (I use the 2.18) version)
>> is working in editing with a postgis view .
>> Thx.
>> A.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Andrea Peri
qwerty àèìòù
