[Qgis-user] Editing a Postgis view
Carlo A. Bertelli (Charta s.r.l.)
carlo.bertelli at gmail.com
Wed Nov 16 06:54:32 PST 2016
Ciao Andrea,
by default Postgresql views are read only. Even the simplest view made in
Postgresql needs a rule to be updated. After writing a statement for a
view, just take the habit of writing the rules for insert, update, delete.
Please read the chapter on the Rule System in the Postgresql Reference
Manual for the instructions.
c
Message: 6
Date: Wed, 16 Nov 2016 09:39:23 +0100
To: Matthias Kuhn <matthias at opengis.ch>
Cc: qgis-user <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Editing a Postgis view
Message-ID:
<CABqTJk8Bo7fs6qOG=MhO9N50qO5L+JkXAOAgik=tUGWwcKd-WA at mail.gmail.com>
Content-Type: text/plain; charset=UTF-8
Hi Matthias,
thx for response.
So the trouble is in my db.
Now I try to understand better why it is not working.
This is my actual try test:
create table schemaapp.repository(
ID serial primary key NOT NULL,
UUID varchar(50) NOT NULL,
PROGETTO varchar(9) NOT NULL,
PROCEDIMENTO text NOT NULL,
GEOMETRIA1 geometry(MULTIPOINT, 3003)
create view schemaapp.v_repository_point as
select
a.id as id,
a.uuid as uuid,
a.progetto as progetto,
a.procedimento as procedimento,
a.geometria1 as geometria
from
schemappa.repository_wfs as a
where
a.geometria1 is not null;
I will know if discover something.
thx again.
2016-11-16 8:54 GMT+01:00 Matthias Kuhn <matthias at opengis.ch>:
> Hi Andrea,
> It works here.
> Do you have an instead of insert rule written on your view?
> It works for me this way (but my views are too complicated for postgres
> to create default insert rules by default anyway).
> You can also try to alter your view with a default value for the column
> in question.
> Best regards
> Matthias
> On 11/16/2016 08:15 AM, Andrea Peri wrote:
>> Hi,
>> I'm having some trouble to edit a postgis view using qgis.
>> The view is a simple:
>> select list-of-field from table1;
>> And the table1 is a table with a Primary key on a serial type field.
>> I add the first record and all was ok. The commit too.
>> When go to add the second record.
>> I start to have trouble.
>> The qgis report my always a constraint violation of the pk.
>> I try to leave the pk field empty, or try to fill it with a value.
>> No solution work.
>> So my question is if is confirmed that qgis (I use the 2.18) version)
>> is working in editing with a postgis view .
>> Thx.
>> A.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161116/0d44fdfd/attachment.html>
