[Qgis-user] different buffer for the same field
Randal Hale rjhale at northrivergeographic.com
Wed Nov 16 03:42:09 PST 2016
In the processing Toolbox there is a tool called Variable Distance Buffer.
If you add a field to your data giving each type a width (field called
bufferwidth and it is 10, 20, 30 , 40 meters for each type) - you can
use that tool to automatically buffer each fault accordingly.
Good Luck!
Randy
On 11/15/2016 07:26 PM, Azzurra Lentini wrote:
> Dear all,
> I have a shape file with a field called “type”.  In the “type”  field
> I have 4 kinds of samples ( 19 records).
> See in the attachment.
> The 4 samples are: normal fault, inverse fault, overthrust, syncline.
> I would like to create a buffer with different distance for each
> sample (the best it would be to obtain a shape with 5 different buffer
> distances).
> For example  the buffer distance for the sample “ normal fault” is 30
> m, for the “inverse fault “ is 20 m, for the “overthrust” is 50 m and
> for the “syncline” is 20 m.
> How I can do this kind of buffer??
> Thanks A.L.
> Dr. Hydrogeologist
> AZZURRA LENTINI
> Expert of evaluation environmental hazards
> GIS application
> Haity Mobile Tel: 0050946057393
> Italy Mobile Tel.: **(39) 338 24 40 676
> SKYPE azzurrahydro
> azzurralentini at gmail.com <mailto:azzurralentini at gmail.com>
> *Par respect pour l'environnement,*
> *n'imprimez ce mail qu'en cas d'absolue nécessité*
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Randal Hale
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161116/6ae71efc/attachment.html>
