[Qgis-user] Problem with Using Google maps -Showing the points not exactly after exporting as a pdf or png
damien stephens
damien.stephens at gmail.com
Thu Nov 17 01:51:04 PST 2016
don't use the open layers plugin, use the quickmapservices one instead.
then hit the get contributed pack.
there are lots of different satellite images in there as well as plenty fo
topographic style map options, and they all print properly.
On Wed, Nov 16, 2016 at 9:16 PM, Nicolas Cadieux <
nicolas.cadieux at archeotec.ca> wrote:
> Hi,
> This is a well know issus with this plugin. The easiest way is to zoom on
> the area and to save the image (save as image). Pan and zoom and do this a
> few times. Then open these images in Qgis. Keep in mind that there are
> limitations on the use of Google Earth images. I wonder if this error is
> intended to discourage people from printing the images...
> Nicolas
> Le 16 nov. 2016 à 05:21, much_milk [via OSGeo.org] <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5296037&i=0>> a écrit :
> Hello,
> i have a big problem with the exposition of the point-shapes in context
> with openlayers plugin cards via google earth.
> The programm showes me every point in the right place (no matter which
> view) but when i export the layout as a pdf or png the points are not on
> the same place where they hast o be.
> I’m still go mad!
> Where is the error or what make i wrong??
> Thanx a lot !
> Bernd
> Qgis-user mailing list
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5295992&i=0>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/Problem-with-Using-
> Google-maps-Showing-the-points-not-exactly-after-
> exporting-as-a-pdf-or-png-tp5295992.html
> To start a new topic under Quantum GIS - User, email [hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5296037&i=1>
> To unsubscribe from Quantum GIS - User, click here.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: Problem with Using Google maps -Showing
> <http://osgeo-org.1560.x6.nabble.com/Problem-with-Using-Google-maps-Showing-the-points-not-exactly-after-exporting-as-a-pdf-or-png-tp5295992p5296037.html>
> Sent from the Quantum GIS - User mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
> Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161117/ea5a6ddf/attachment.html>
