[Qgis-user] QGIS 2.18 on yakkety
Andre Joost andre+joost at nurfuerspam.de
Sat Nov 19 02:20:20 PST 2016
Am 15.11.2016 um 15:01 schrieb Jens Eligehausen:
> Since both repo don't "support" yakkety (I tried xenial) I deactivated
> both repositories
That does not work. You have to stick to the packages for your OS. If
Ubuntugis unstable has nothing for yakkety, you have to take the qgis
debian packages. But be sure to remove the ubuntugis packages from your
hard disk before installing.
http://qgis.org/debian/dists/yakkety/main/binary-amd64/Packages lists
the available packages.
> but even 2.14.5 installed from the Ubuntu repo leads
> broken python support.
According to http://packages.ubuntu.com/yakkety/qgis it should work.
Please include the dependency messages you get.
HTH,
André Joost
