[Qgis-user] QGIS take several minutes to start on Windows 7
Andreas Neumann
a.neumann at carto.net
Mon Nov 21 12:00:24 PST 2016
Hi Cliff,
I don't really know what is going on on your machine.
Just a shot in the dark: if you run an antivirus software, try to
disable it and see if it helps.
The other guess would be plugins, but you said that you already tried
starting with the --noplugins switch, so that doesn't help either ...
Hope you are able to find out what the problem is.
Andreas
Am 21.11.2016 um 20:53 schrieb Régis Haubourg:
> Hi Cliff,
> this reminds me of a nasty thing I encountered before.
> I logged all there:
> http://osgeo-org.1560.x6.nabble.com/Qgis-first-startup-is-slow-td4975911.html
> I disappeared when reinstalling a new version, without clearly
> understanding what happened. Final tests let think that something was
> weird with windows shared file system where profiles where stored.
> What is your exact OS version?
> All I can advice is to log all what happens with process_monitor.exe
> and look at the errors you get.
> Also, can you tell us:
> What happens in those test cases?
> - launch qgis again while first instance has not startup yet
> - launch qgis using configpath option with a profile on another drive
> than currently (network or local?)
> - is the second startup faster than the first one ? (if yes you have
> another Microsoft windows phenomenon called cold startup cumulating
> itself with previous one)
> Thanks for your tests, you face a really rare issue that we must
> narrow down and solve, really
> Cheers
> Régis
> 2016-11-21 20:15 GMT+01:00 Cliff Patterson <cliffpatterson at gmail.com
> <mailto:cliffpatterson at gmail.com>>:
> Greetings,
> On a new Dell laptop running Windows 7 (i7, 8GB ram), it takes
> about 3-5 minutes for QGIS to start, which is a hassle. It hangs
> at “Starting up the GUI” and if I click on the splash screen, it
> crashes, but if I let it sit it eventually starts without any
> error. I have had this problem since installing QGIS 2.14 using
> the OSGeo4W 64-bit installer. I have since completely removed that
> installation, deleted the .qgis folder, and deleted all registry
> entries. I then reinstalled using the standalone installer and
> still no luck. I currently have QGIS versions 2.14, 2.16, and 2.18
> installed and experience the same problem with each.
> Other steps I've taken were to disable plugins and remove plugins,
> but no change on startup.
> I have the same versions running on another Windows 7 machine and
> a Linux VM with no problems.
> The only error I see in the logs is the following:
> 2016-11-21T13:37:48 1 Failed to load
> C:/PROGRA~1/QGIS2~1.14/apps/qgis-ltr/plugins/globeplugin.dll
> (Reason: Cannot load library
> C:/PROGRA~1/QGIS2~1.14/apps/qgis-ltr/plugins/globeplugin.dll: The
> specified procedure could not be found.)
> Does anyone know what could be causing QGIS to boot up so slowly?
> Cheers,
> Cliff
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> <http://lists.osgeo.org/mailman/listinfo/qgis-user>
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161121/9a43673f/attachment.html>
