[Qgis-user] suddenly unable to open shape files
Mira Kattwinkel kattwinkel-mira at uni-landau.de
Fri Nov 25 09:10:10 PST 2016
Hello Nicola
Thanks for the suggestion but this is not the problem. I did not move
any files and it happens with whatever shape file I try.
Mira
On 25/11/16 17:58, Nicolas Cadieux wrote:
> Hi,
> Perhaps you moved or copied the shape files and forgot to move the
> accompanied files (3 to 8 files with different extensions like .shx
> .dbf .shp .prj)?  If you just move the .shp and not the others, this
> is will create errors.  The .shx contains the geometries.  You may get
> this kind of message if you try to drag and drop the .shx and not the
> .shp in QGiS.
> .tiff will not crash because it's a lone file.
> Nicolas
> Le 25 nov. 2016 à 11:36, Mira Kattwinkel [via OSGeo.org
> <http://OSGeo.org>] <[hidden email]
> </user/SendEmail.jtp?type=node&node=5297448&i=0>> a écrit :
>> Dear list
>> I have been working with QGIS 2.14 and now 2.18 for a while on Linux
>> Mint 17. Suddenly, I cannot open shape files any more. When trying to
>> load them I get the message: "Layer is not valid: The layer XX.shp is
>> not a valid layer and can not be added to the map."  In the log message
>> panel under ogr it says: "Data source is invalid (Unable to open XX.shx
>> or XX.SHX.Try --config SHAPE_RESTORE_SHX true to restore or create it)"
>> Additionally, I cannot open GRASS files any more (which also used to
>> work fine) and get the error:" Error reading database file from:
>> /usr/share/qgis/resources/srs.db Because of this the projection selector
>> will not work..." and then QGIS crashes.
>> Interestingly, I can open shape files from my file browser (it starts
>> QGIS and loads the file) but then I cannot add another one. Raster
>> (GeoTif) data are also fine.
>> I have no idea what's causing this. I have tried removing and
>> reinstalling QGIS (version 2.18 and 2.14) without any success.
>> Can anybody give me any hint what might have corrupted my system?
>> Thanks a lot,
>> Mira
>> Qgis-user mailing list
>> [hidden email] </user/SendEmail.jtp?type=node&node=5297446&i=0>
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> If you reply to this email, your message will be added to the
>> discussion below:
>> http://osgeo-org.1560.x6.nabble.com/suddenly-unable-to-open-shape-files-tp5297446.html
>> To start a new topic under Quantum GIS - User, email [hidden email]
>> </user/SendEmail.jtp?type=node&node=5297448&i=1>
>> To unsubscribe from Quantum GIS - User, click here.
>> NAML
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: suddenly unable to open shape files
> <http://osgeo-org.1560.x6.nabble.com/suddenly-unable-to-open-shape-files-tp5297446p5297448.html>
> Sent from the Quantum GIS - User mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html>
> at Nabble.com.
Dr. Mira Kattwinkel
Quantitative Landscape Ecology
Institute for Environmental Sciences
University of Koblenz-Landau
Fortstraße 7
76829 Landau
Germany
Phone: + 49 6341 280-31553
Office: Building I, Room 2.02
