[Qgis-user] suddenly unable to open shape files
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri Nov 25 09:17:10 PST 2016
Zip me the file if it's not confidential. I can test it.
> Le 25 nov. 2016 à 12:07, Mira Kattwinkel [via OSGeo.org] <ml-node+s1560n5297449h80 at n6.nabble.com> a écrit :
> Hello Nicola
> Thanks for the suggestion but this is not the problem. I did not move
> any files and it happens with whatever shape file I try.
> Mira
> On 25/11/16 17:58, Nicolas Cadieux wrote:
> > Hi,
> > Perhaps you moved or copied the shape files and forgot to move the
> > accompanied files (3 to 8 files with different extensions like .shx
> > .dbf .shp .prj)? If you just move the .shp and not the others, this
> > is will create errors. The .shx contains the geometries. You may get
> > this kind of message if you try to drag and drop the .shx and not the
> > .shp in QGiS.
> > .tiff will not crash because it's a lone file.
> > Nicolas
> > Le 25 nov. 2016 à 11:36, Mira Kattwinkel [via OSGeo.org
> > <http://OSGeo.org>] <[hidden email]
> > </user/SendEmail.jtp?type=node&node=5297448&i=0>> a écrit :
> >> Dear list
> >> I have been working with QGIS 2.14 and now 2.18 for a while on Linux
> >> Mint 17. Suddenly, I cannot open shape files any more. When trying to
> >> load them I get the message: "Layer is not valid: The layer XX.shp is
> >> not a valid layer and can not be added to the map." In the log message
> >> panel under ogr it says: "Data source is invalid (Unable to open XX.shx
> >> or XX.SHX.Try --config SHAPE_RESTORE_SHX true to restore or create it)"
> >> Additionally, I cannot open GRASS files any more (which also used to
> >> work fine) and get the error:" Error reading database file from:
> >> /usr/share/qgis/resources/srs.db Because of this the projection selector
> >> will not work..." and then QGIS crashes.
> >> Interestingly, I can open shape files from my file browser (it starts
> >> QGIS and loads the file) but then I cannot add another one. Raster
> >> (GeoTif) data are also fine.
> >> I have no idea what's causing this. I have tried removing and
> >> reinstalling QGIS (version 2.18 and 2.14) without any success.
> >> Can anybody give me any hint what might have corrupted my system?
> >> Thanks a lot,
> >> Mira
> >> _______________________________________________
> >> Qgis-user mailing list
> >> [hidden email] </user/SendEmail.jtp?type=node&node=5297446&i=0>
> >> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> >> If you reply to this email, your message will be added to the
> >> discussion below:
> >> http://osgeo-org.1560.x6.nabble.com/suddenly-unable-to-open-shape-files-tp5297446.html
> >> To start a new topic under Quantum GIS - User, email [hidden email]
> >> </user/SendEmail.jtp?type=node&node=5297448&i=1>
> >> To unsubscribe from Quantum GIS - User, click here.
> >> NAML
> >> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> > View this message in context: Re: suddenly unable to open shape files
> > <http://osgeo-org.1560.x6.nabble.com/suddenly-unable-to-open-shape-files-tp5297446p5297448.html>
> > Sent from the Quantum GIS - User mailing list archive
> > <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html>
> > at Nabble.com.
> > [hidden email]
> Dr. Mira Kattwinkel
> Quantitative Landscape Ecology
> Institute for Environmental Sciences
> University of Koblenz-Landau
> Fortstraße 7
> 76829 Landau
> Germany
> Phone: + 49 6341 280-31553
> Office: Building I, Room 2.02
> [hidden email]
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/suddenly-unable-to-open-shape-files-tp5297446p5297449.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/suddenly-unable-to-open-shape-files-tp5297446p5297452.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161125/71bd4b81/attachment.html>
